Door adjustments
Old January 6th, 2012, 06:35 AM
rmoths's Avatar
Wink Door adjustments
Well I'm going to buy a 1972 Cutlass convertible, picking it up on Sat.
The doors need to be adjusted, they are a little low. They need to be lifted just a little when you close them. I hope I can loosen the door mounting bolts and move it up a little. Or if someone knows the proper way to adjust them I would really appreciate the help. Thanks Barb.
rmoths is offline
Old January 6th, 2012, 08:05 AM
oddball's Avatar
The hinge pins are worn out. You can either get new hinges or get hinge repair kits. Most of the resto houses carry them.
Not a terribly easy job, doors probably need to come all the way off.
oddball is offline
Old January 6th, 2012, 08:19 AM
Oldsmaniac's Avatar
Yes this is the 1st thing to check but since it is a convertible hopefully the frame is solid as they are prone to rot. Sometimes too the catch pin can be adjusted slightly to make up for the worn hinge pins.
Oldsmaniac is offline
Old January 6th, 2012, 08:41 AM
Auto parts stores sell a brass bushing kit (and a special tool, if you want to try to use it) to repair the hinges, or, as has been mentioned, they can be replaced.
To be sure it's the hinges, just pick up the end of the door and lift - if you can pick the door up and lift it freely about ¼-½" (especially if you can watch the hinges and see the movement there, or hear the play at the hinge pins as you wiggle it), then it's the hinge.
Door hinges, especially the driver's side, are a reliable wear marker, so if they're shot, the car has likely got a lot of mies on it. If you're buying it as a "low mileage" car, they're lying.
Also, as Joe said, "sagging" doors are a sign of frame (or unibody) rust on convertibles - if the hinges aren't worn, I'd watch out. If the seller lets you put a floor jack right under the back of the door (and, no, I don't recommend actually jacking a convertible up this way) and lift it a few inches, and if there isn't much change in how things fit (there will be some change, even if it's a time-capsule, "brand-new" car), then you're probably good.
If the seller flips out at the idea, then you should just keep walking.
MDchanic is offline
Old January 6th, 2012, 10:08 AM
rmoths's Avatar
OK Thanks for the reply. The undercarriage frame, All looked good. Never gave the car sag a thought. If that were the case I hope you would see a rusty frame. Now you've got me scared, I'll give it another good look before I buy.
Thanks Barb.
rmoths is offline
Old January 6th, 2012, 10:24 AM
Remember, they all have some flex if you jack them up right at the edge of the door (which you are not supposed to do) - my personal estimate would be about half an inch at the top of the door - but a "sagging door" can be a sign of a bad frame (if it is a bad frame, then you'll be able to close the door with the car empty, but it will seem hard to close with you sitting it it, and it won't close with a carload of passengers).
MDchanic is offline
Old January 6th, 2012, 10:44 AM
frankr442's Avatar
I have a hardtop but I'm pretty sure converts have small brass strikers or wedges on the upper rear corner of the door to help with rigidity and avoid door sag. See if they're still there, maybe the doors were swapped?
frankr442 is offline
spate51
Body work
August 1st, 2012 04:18 AM
1973olds98
November 24th, 2010 02:19 AM
Ausraven
November 2nd, 2010 08:57 PM
nelsontj
March 4th, 2009 03:33 PM
aristellier
October 4th, 2006 04:50 AM
Quick Reply: Door adjustments
