Clock Delete 67 cutlass
Since you have gotten no responses I figured I would. This may be of no help but may get you looking around and give you some thoughts. If you have Ac there may be a duct that has to be removed for better access. If it is anything like the 68-69 gauges you will need to loosen 2 1/4" hex screws to remove it. You will have to get your hand up there and feel around for them. I think I was able to use a small ratchet with a socket and a hex driver to get at them. It will pull out from the rear.
Good Luck, you can do it!
Steve
Steve
