Clock Delete 67 cutlass
Old May 3rd, 2022, 03:53 PM
ORANGE CRUSH's Avatar
Can anyone give me the steps to remove the clock delete from a 67 cutlass no a/c so I can put a tach in its place
ORANGE CRUSH is offline
Old May 4th, 2022, 06:43 AM
Phoenix8990's Avatar
Since you have gotten no responses I figured I would. This may be of no help but may get you looking around and give you some thoughts. If you have Ac there may be a duct that has to be removed for better access. If it is anything like the 68-69 gauges you will need to loosen 2 1/4" hex screws to remove it. You will have to get your hand up there and feel around for them. I think I was able to use a small ratchet with a socket and a hex driver to get at them. It will pull out from the rear.
Good Luck, you can do it!
Steve
Phoenix8990 is offline
Old May 4th, 2022, 07:20 AM
nicks1966's Avatar
three screws in the back to remove
nicks1966 is offline
Old May 4th, 2022, 03:33 PM
Thank you but looking for photo from under the dash as I cant see the clock delete
when looking up under dashboard or the steps to get to it
Old May 5th, 2022, 05:11 AM
Laying on your back, head up against the pedal, stick your arm up there and feel around with a nut driver. Sometimes these things are done blind. It would be nice if it was easier.
Steve
Old May 5th, 2022, 05:15 AM
Oldsmaniac's Avatar
If your car has AC most likely all the ducting needs to come out to access.
Oldsmaniac is online now
Old May 5th, 2022, 01:37 PM
ok thanks I will try but cant see too much
JOHNNYOLDS442
November 19th, 2015 07:39 PM
OLDSmobility
March 12th, 2011 02:54 AM
D Appeldorn
October 19th, 2010 11:26 AM
squirell
November 20th, 2009 06:34 PM
Flye
November 1st, 2009 07:57 AM
Quick Reply: Clock Delete 67 cutlass
