68 cutlass flywheel/starter
i am putting together my 68 cutlass 4 speed muncie transmission and dont have the original flywheel all research says 166 tooth flywheel goes in it but with aluminum bellhousing starter doesent fit it hits flywheel anyone else run into this problem?
If you do not have the correct Oldsmobile flywheel, I just happen to have an NOS flywheel in the box. If you are located close enough to Red Oak Tx, to pick it up, I will take $200. Will not ship.
getitmann
August 18th, 2013 06:44 PM
