65 starfire
Old July 16th, 2006, 04:43 PM
phantom.10's Avatar
65 starfire
Looking for the correct date year heads and a intake for my 65 starfire..
Any info on repairing a leak in the heat riser valve ???
phantom.10 is offline
Old July 16th, 2006, 05:05 PM
Tom Servo's Stunt Double
texasred's Avatar
If it's a 330, heads are B = 385101.
400 and 425s are C = 383821
Sorry I can't help you on the intake or heat riser.
C.J.
texasred is offline
Old July 17th, 2006, 06:42 AM
Past Administrator
Oldsguy's Avatar
If you are talking about the valve in the exhaust manifold, those are really prone to rusting up as any component is in the exhaust sytem. Your best bet would be to try using some PB Blaster or similar agent to break the rust loose. Apply it to the shaft the valve is mounted to and the pivot points in the manifold itself. Of course this means removing the exhaust to get to the inside. Apply this stuff for three or four days a couple of times per day before you ever try to move the valve, let it get a good soak. Then try to move the valve on it's axis, hopelfully you will be able to break it free without any damage, then just reassemble the manifold to the head.
Oldsguy is offline
Old July 17th, 2006, 02:56 PM
phantom.10's Avatar
Thanks Oldsguy...will do
1962oldsguy
May 19th, 2019 08:08 PM
Kyle's 77 Cutlass
January 1st, 2014 09:06 AM
Oldssupreme
February 3rd, 2013 06:26 AM
Oldssupreme
February 3rd, 2013 06:24 AM
slhandpaz
October 24th, 2005 05:17 PM
Quick Reply: 65 starfire
