Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
O4 chevy cavalier5speed 2.2 ecotech
Old August 28th, 2018, 08:42 PM
Thomas Diefel's Avatar
Just installed new timing chain kit 5 months ago n now in every gear right before i shift up it has that loose timing chain noise. I took the timing chain cover off n. Rotated engine 20 full turns n found it lil loose in a half rotation.what would cause that
Thomas Diefel is offline
Old August 28th, 2018, 08:55 PM
edzolz's Avatar
Did you replace both gears or just the chain. If you replaced the gears, were both gears all steel or was the upper gear coated with plastic like OEM gear. Maybe the oiler plug that squirts oil on the chain is plugged and not lubing the chain as it should.
edzolz is offline
76 Regency
August 9th, 2020 10:30 AM
73aussie455
April 18th, 2014 02:41 PM
rallye455
January 1st, 2011 07:10 PM
Goofy
December 31st, 2010 08:42 PM
Robertoho
February 7th, 2009 05:37 AM
Quick Reply: O4 chevy cavalier5speed 2.2 ecotech
