Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS1 swap in a fullsize olds
Old February 24th, 2014, 11:50 PM
dantecl's Avatar
Hey guys,
So right now I've got my 455 running and all, but at some point I'm likely going to swap it all for an LS1 with a 4L60E, and I wanted to get some input on a few things...
- How does the column shifter get to work with the new tranny?
- What are the options when it comes to dash gauges? New cars have all the digital stuff and my car has negative digital stuff.
- Is there any body work involved in fitting the engine + tranny or is it just a matter of adapting mounts to fit them?
Dante
dantecl is offline
Old February 25th, 2014, 02:58 AM
garys 68&72's Avatar
On the shifter, go check on the LS1tech conversions page. There are companies that make parts for that.
Gauges, you can use your original senders for temp, oil, etc. Speedo is a problem. There are modified trans tailstocks to run a mechanical speedo or a cable X module.
Given the size of a 455/th400, the LS/4L60 should fit easily, Mkight have to move the crossmember and change the driveshaft.
garys 68&72 is offline
gearheads78
Non-Olds Engines
December 3rd, 2010 07:55 PM
reesejames
March 6th, 2010 05:58 AM
altereddoug
November 25th, 2009 06:10 PM
ratrocket
April 9th, 2009 07:30 AM
1FSTLS1
May 30th, 2008 07:42 AM
Quick Reply: LS1 swap in a fullsize olds
