Jahns Pistons how to ID ?
Sorting the 66-67 Olds parts collection continues.
Included in the 66-67 Olds parts collection, were a set of new Jahns Pistons.
Unfortunately the box label was missing part number. I'm guessing it's from the 70's based on age of box and shipping label typewriter font.
Did some research and back in the day Jahns was a no frills budget piston.
Didn't see any part number inside the piston only the name.
I can have a machine shop micrometer size, but not sure if that will help identifying what they are.
I found them next to a set of standard Oldsmobiling 350 Pistons and rings.
Mader
jm68442@yahoo.com
Mader
jm68442@yahoo.com
Mader
jm68442@yahoo.com
Mader
jm68442@yahoo.com
If your machine shop can measure the piston diameter and the pin height that is all you need to properly identify them. They almost look to me like they have a small dome on them. Hard to tell for sure by the picture. Are you certain there are no numbers on the pistons anywhere ?
What is on the label where you have it blacked out ??
I blacked out the ship to address.
I'll have to dig out the piston tote.
The wrappings disintegrated on the one I looked at, put it back in box then snapped a pic.
Pins are pressed in, but Pistons have been sitting for a long time.
Mader
Mader
Actually Jahns was one of the early race piston manufacturers and as far as I now they were very good for their time, certainly "not no frills budget"
I bet the pins are just stuck,pins press into the rod,not the pistons.
I'll just have to make time to visit my machine shop and get Pistons measured.
I'm curious to know what they are.....
Mader
Mader
6.15 update
While loading totes into trailer for homecoming, I looked again at box and other end had part number.
I called JE Automotive but their records didn't go that far back.
It's part number 8-1156 H RP
.60 over with 13:1 compression ratio with 1/8 dome.
I'll search later.
Mader
I'll search later.
Mader
