VIN Locations
Old January 17th, 2015, 05:59 PM
vikingharley's Avatar
Cool VIN Locations
I just bought a 1969 Cutlass S and trying to find the VIN locations on the car. Can anyone help? Much appreciated!!!
vikingharley is offline
Old January 17th, 2015, 06:13 PM
dnmfranco's Avatar
vin will be under windshield on driver side, the numbers will be something like 334967 for example will have either the letter m,z,e or 1 for Canada
the cowl tag will be on top of driver side cowl and will be aluminum plate
which will decode build date , colors ,build sequence and sometimes options are listed
the vin will also be on motor and tranny as well
dnmfranco is offline
Old January 17th, 2015, 06:19 PM
dnmfranco's Avatar
Also the motor and tranny if original to car will both start w 39 letter of plant and remaining digits should match the remaining numbers in your vin location.
for example 39m34567 this is what you would see on the motor pad which is on driver side towards the front by power steering pump.
Tranny will on driver side same sequence
Old January 17th, 2015, 06:36 PM
Talking 1969 vin locations
Thanks guys I hope everything matches...I'll go check
Old January 17th, 2015, 06:38 PM
dnmfranco's Avatar
If you post a pic of cowl tag can tell you everything about it
68ramrod350
March 30th, 2015 09:16 PM
RED4467
May 6th, 2013 07:42 PM
RAMBOW
September 14th, 2011 08:54 AM
HoustonS88
June 1st, 2011 12:02 PM
1BAD68"S"
August 20th, 2006 08:06 PM
Quick Reply: VIN Locations
