'69 Delta eighty-eight Custom. 455
the car is original. just under 65k miles. Edelbrock Perf Intake, Demon 650, hei distrib.
Been sitting for about 7 years after my uncle passed away (was his car). The holly fuel pump he had on was leaking, and after ordering three diff pumps through O'reilys and some fitting adjustments/tweaks, I got one installed tonight. (the outlets on the pump for the three lines all face the block and run straight into the frame/crossmember)
I think there is a clog somewhere or a kink maybe in the hard lines somewhere because im not getting fuel from the tank to the pump. If the tank wasn't bone dry it was close so there shouldn't be any gelatin crap in the tank but im waiting to drop it until I absolutely have too.
has anyone ever revived one that's been sitting outside that long?
If anyone can shed a little light on this subject I would greatly appreciate it.
thanks
Nick
thanks
Nick
If the gas tank is dead empty, that would certainly explain a lack of fuel.
If you've put a few gallons in it, then consider porous cracked fuel hoses, or rust pinholes in the steel lines. A holed fuel pump diaphragm is also not out of the question.
Pouring some gas right down the carb. would bypass these issues, and even with a few pinholes, will often pull the fuel past them and get 'er running.
Welcome to ClassicOlds.
