choke heat tube
Old April 10th, 2011, 11:08 AM
74droptop's Avatar
choke heat tube
I have a 1974 delta 88 convertable with a 455 i'm trying to figure out how the heat tubes are routed on the quadrajet carb. If any one has a pic it would be great? thanx Jeff
74droptop is offline
Old April 10th, 2011, 12:51 PM
Gary
Gary's 2 442-S's Avatar
I hope this is what you are asking for. I just so happen to be replacing the choke heat stove.
Gary's 2 442-S is offline
Old April 10th, 2011, 01:58 PM
74droptop's Avatar
heat tube
Where does the long tube go on back of carb????
Old April 10th, 2011, 02:19 PM
Here's a picture of a DualJet - QuadreJet hooks up the same way.
See the long tube going to the port on the back of the carb. to pull in air from inside the air cleaner?
MDchanic is offline
Old April 12th, 2011, 06:01 AM
Past Administrator
Oldsguy's Avatar
That's right Eric.
Welcome to our site Jeff.
Oldsguy is offline
Old April 19th, 2011, 01:37 PM
74droptop's Avatar
choke heat tubes
Thanx for the help with the choke heat tubes. Put remanufactured carb on with new tubes and it works great. How do i do a new post on another subject?
88hurstolds
November 14th, 2014 12:07 PM
dingusboy
March 8th, 2014 07:09 AM
oldspackrat
December 6th, 2012 02:48 AM
kgenesse
February 21st, 2010 06:00 AM
bjtstarfire
November 13th, 2008 02:04 PM
Quick Reply: choke heat tube
