Thermostat gasket leak
Old April 28th, 2024, 06:05 AM
Trax's Avatar
Question Thermostat gasket leak
I have a 1969 400 BB that is leaking from the thermostat gasket. One of the bolts for the water outlet is obviously stripped and was considering trying to repair with "helicoil" thread repair. I have never used this product and don't know anything about it. My questions are:
!. Is this a good acceptable repair?
2. Can this repair be made in place or does the manifold need to be removed from the engine?
Trax is offline
Old April 28th, 2024, 06:22 AM
Heli-coiling the threads is a permanent repair. It'd probably be easier to do it with the intake manifold on the bench vs. installed on the engine.
Olds64 is offline
Old April 28th, 2024, 06:25 AM
It can be done with the manifold in place, use a thread sealer on both the helicoil and the bolt.
oldcutlass is offline
Old April 28th, 2024, 11:05 AM
OLDSter Ralph's Avatar
Be sure to get the right length Heli-coil. Too long is not good.
Make sure the "tail" is 1 to 1 1/2 threads below the gasket surface.
Read the instructions and use sealer as suggested by Oldcutlass.
OLDSter Ralph is offline
Old April 28th, 2024, 11:23 AM
oldolds88's Avatar
after Heli coil mine, I used studs in place of the bolts. Another fix is keen serts, i like those better than the coils'.
oldolds88 is offline
Old April 28th, 2024, 03:58 PM
davek1661's Avatar
A friend used helicoils back in the day, and they came out next time he had to pull the bolt, so using a stud is probably a great idea. I have a Suzuki with an aluminum oil pan, previous owner used a helicoil when the oil drain plug threads stripped, and when I pulled the drain plug, the helicoil came out with it. Drain plug is steel, so someone probably over tightened it. I replaced the oil pan. When I have a stripped hole, I generally just drill it out and tap a new thread one size larger, but a cast iron manifold might be hard to tap. If it doesn't work out, you can replace the manifold. It's only money after all!
davek1661 is offline
Old April 28th, 2024, 07:00 PM
Sugar Bear's Avatar
Yes it is an acceptable repair. It should be able to be easily done in place. If you've drilled a hole and tapped threads you've mostly done this and didn't know it. It is pretty easy just drill straight!!!
Sugar Bear is offline
Old April 29th, 2024, 05:19 AM
Trax's Avatar
Thanks for the advice guys. Seems a lot easier and cheaper than purchasing a new $500 manifold.
Trax is offline
maineolds
July 17th, 2021 03:47 PM
Sarum
March 7th, 2015 07:20 AM
my71olds
May 2nd, 2013 04:00 PM
jaunty75
May 28th, 2011 12:14 AM
shaks 442 clone
July 18th, 2007 05:03 AM
Quick Reply: Thermostat gasket leak
