Floorboard Issues
Old June 17th, 2011, 06:07 AM
Doug in SD's Avatar
Floorboard Issues
OK, here,s the situation, I have 5 or 6 small pinholes in my floor (drivers side) do I try to cut out about 1" squares and fix them, or just replace the whole pan. I plan on cleaning the whole thing good and applying POR15 on both sides. I have never done a restoration like this before. I did successfully repair the rust on my radiator support.
Thanks in advance
Doug in SD is offline
Old June 17th, 2011, 06:12 AM
Tony72Cutlass'S''s Avatar
I'd probably cut out a little more than 1'' squares, or at least until you absolutely see no corroded metal or rust, i had a hole the size of a quarter in my floor pan a few weeks ago, i ended up cutting out a hole that i could fit my foot in just because the metal around it was very weak. But if you can fix it, i'd totally go for it.
-Tony
Tony72Cutlass'S' is offline
raw442
April 11th, 2012 07:54 PM
Adogg
May 8th, 2011 05:18 AM
2blu442
September 15th, 2010 03:29 PM
macarthur
July 25th, 2006 12:46 PM
<Brian>
September 9th, 2004 09:38 AM
Quick Reply: Floorboard Issues
