'70 Vista Cruiser Project
Old August 15th, 2010, 03:39 PM
  #361
2blu442's Avatar
So the damaged fender did not give up it's heel in vain!
Thank you for posting all the pictures you have on this build. One of my goals this summer was to try and fix all the rusted window channels on my collection. I've been using plastic tarps on them to reduce the water damage in the winter, but that cooks the paint off the metal, and I'm getting tired of spending $150 a year on tarps that only last one season. But the summer is getting away from me again and work is taking too much of my time!
Back to your car, the pictures will help guys like me know how it should look if we do it right. Keep up the good work Erik and by all means keep posting pictures
2blu442 is offline
Old August 16th, 2010, 06:18 PM
  #362
Beob's Avatar
Hey Erik, good to see you back in action again. Progress looks great. Do you have much more metal work? Rob
Beob is offline
Old August 16th, 2010, 08:25 PM
  #363
Registered Luser
ent72olds's Avatar
What's up Rob? Only bodywork left is 2 fenders......rest of car is primed. Finally went to Bellmore for 1st time this year Fri nite! Will probably go again this Fri! You should go!!!!
ent72olds is offline
Old August 17th, 2010, 11:28 AM
  #364
Beob's Avatar
Sounds good, I will go. The last time I went was in june and the cops shut it down. Then it moved to Massapequa, but if you say its open I will be there!
Beob is offline
Old August 17th, 2010, 06:59 PM
  #365
Registered Luser
ent72olds's Avatar
Yes, back to normal at Bellmore....I'll probably bring my '72 this time.....
Old August 17th, 2010, 07:36 PM
  #366
Registered Luser
ent72olds's Avatar
Went back at it tonight, working on the pass fender bottom...same as the other fender, just had to cut higher due to more extensive rot...
Old August 17th, 2010, 07:38 PM
  #367
Registered Luser
ent72olds's Avatar
Again, I transferred the cut to the "new" fender bottom, leaving the brace accessible!
Old August 17th, 2010, 07:43 PM
  #368
Registered Luser
ent72olds's Avatar
I then cut out the outer skin of the replacement panels for two reasons...1-they were rough and B-it allowed my bro to media blast the other side of the brace for a thorough job! He then applied POR-15 to the inside while we had access. These bottoms will never rust again!!!!
Old August 18th, 2010, 02:14 AM
  #369
Registered
Bluevista's Avatar
Are you going to weld those seams Erik?
Seems like overkill, I would just use liquid nails to stick it together, the woodgrain vinyl will cover it.
They don't call it panel adhesive for nothin'.
Bluevista is offline
Old August 19th, 2010, 05:41 PM
  #370
Registered Luser
ent72olds's Avatar
Spoken like a true carpenter.........hey Allan, at least you're not a butcher!!!! Not that there's anything wrong with that...just that in my business, butcher is a derogatory term.....
Old August 19th, 2010, 05:47 PM
  #371
Registered Luser
ent72olds's Avatar
Started working on a "patch for the patch"! I spot welded the fender bottom on, and spent about an hour getting the line between the fender and door acceptable....gotta say, the '70-'72 model year fenders for an olds A-body are about the worst to line up!!! The patch looks good, and I even hammer shrunk it to the exact contours.....
Old August 19th, 2010, 08:44 PM
  #372
Registered
Bluevista's Avatar
I shrink bugs with my hammer.
Those fenders are a challenge, it took me 3 years to line mine up.
The day before I took it to be painted I was still messing with the gaps on those along with the hood.
There is a big factory gap between the fender and door and that point on top of the door still gets within a hair when you open it. I guess as long as there's room for paint a miss is worth a mile but it looks scary close.
The tailgate gets tight on the left when you open it sideways too, it started to rub after I put the new seal on , better just to open it the up and down way until the seal breaks in.
I'm going nuts, both my cars are finished, I need something to do...I'm envious of all the fun you're having Erik.
Old August 19th, 2010, 08:59 PM
  #373
Land Yacht Captain
66ninetyeightls's Avatar
Now you've done it. You poked at the gods of fate!!! Best to keep the cars in the garage for a while!!!
66ninetyeightls is offline
Old August 21st, 2010, 07:15 AM
  #374
Registered Luser
ent72olds's Avatar
i COULD PUT YOU TO WORK ALLAN.....like Craig said, I wish I would have left my '72 in the garage last night! First time out in 2 yrs, and I forgot to turn the hood locks! The rest is history....car is now safely back in garage minus hood and hinges.....anybody have a hood for sale?
Old August 21st, 2010, 10:54 AM
  #375
Beob's Avatar
O man, that sucks! Was there any other damage. I was wondering what happened to you. We left Bellmore around 8 then went to Massapequa (thats was better). We must have just missed you. Maybe next week.
Beob is offline
Old August 21st, 2010, 03:16 PM
  #376
Registered
Bluevista's Avatar
Bummer Erik!
I had that happen when I was driving my '56 Furd Victoria many moons ago.
Was it an original OAI type hood?
Old August 21st, 2010, 03:24 PM
  #377
Registered Luser
ent72olds's Avatar
No Allan, it was an all glass deal....Luck for me it was aftermarket, if it was steel braced, it probably would have stayed attached to the hinges....this thing took off like a kite...hinges look like pretzels! Put claim in to Hagerty today....not sure if I replace it or just get an original non w-25 hood...
Old August 22nd, 2010, 06:10 PM
  #378
Registered Luser
ent72olds's Avatar
Welding & Grinding Finished On L/Fender!
Yes, just need to strip and do the bodywork on this fender, and we'll be down to the last panel! After that, it's all downhill.....
Old September 4th, 2010, 08:20 PM
  #379
Registered Luser
ent72olds's Avatar
Talking I Think I'm Done Welding & Grinding!
Well, today I finished welding the other fender up! Made a patch for the patch, welded it up, and ground it down...of course, I hammer shrunk them to the proper contour!
Old September 4th, 2010, 08:23 PM
  #380
Registered Luser
ent72olds's Avatar
I know the pics look repettttettttttive, but it's only 'cause there are two sides to this particular car!
Old September 4th, 2010, 08:25 PM
  #381
Registered Luser
ent72olds's Avatar
Also finished stripping the left fender! It is now ready for pick and file, and plastic work....
Old September 6th, 2010, 04:25 PM
  #382
Registered Luser
ent72olds's Avatar
Picked and filed the left fender today....just need a couple hours to do the plastic work, and then do the right fender! By the time I finish this fender, my bro will be done stripping the right fender.....
Old September 14th, 2010, 06:45 PM
  #383
Registered Luser
ent72olds's Avatar
Finished the plastic work on the left fender tonight! Also finished stripping the right fender....both fenders will be spray poly'd before primer!
Old September 15th, 2010, 01:40 PM
  #384
dk-52's Avatar
Erik, It looks like I showed up late for this party, but it looks like you have it well under control. Its lookin very good!! I love this site, seems I'm always learning from everyone here, Keep up the great work, Dan
dk-52 is offline
Old September 15th, 2010, 02:03 PM
  #385
Registered
Bluevista's Avatar
I approve.
Makes me nostalgical, those Vista bodywork times were the good old days.
I worked on the tops of my fenders alnmost up until the day I took it to be painted. Kept finding dings when I was blocking out the primer.
I see others, not as well prepped, with those dings on the tops of the fenders. I've deduced by location, size and shape that they're caused by pointy elbows leaning on the fenders.
Don't ask me how I deduced, intake manifold weight + elbows x leaning surface metal tensile strength x surface area factor squared is the formula.
Old September 15th, 2010, 06:07 PM
  #386
Registered Luser
ent72olds's Avatar
Thanks Dan.....I agree, it is a great site, with many knowledgable and helpful people!
Old September 15th, 2010, 06:10 PM
  #387
Registered Luser
ent72olds's Avatar
I approve.
I hear you! It seems like every square inch of this car has dings or creases! Now as far as your equation, it looks like something only Joe P. could figure out!
Old September 18th, 2010, 05:22 PM
  #388
Registered Luser
ent72olds's Avatar
Finished the bodywork on the right fender...also was able to spray-poly both fenders today! Only thing left is to block them both, and prime them! After that, I can move to the firewall......
Old September 18th, 2010, 05:25 PM
  #389
Registered Luser
ent72olds's Avatar
I'm very happy with the way these came out, considering how bad the tops were dented, and how rotted the bottoms were....here are some pics in poly!
Old September 22nd, 2010, 08:12 PM
  #390
Registered Luser
ent72olds's Avatar
Bodywork finally complete on car!
Yes it's true...all the bodywork is complete on this monster! Blocked down the spray poly tonight on the fenders, now tomorrow, I will prime them! Next stop, paint firewall and do front suspension....
Old September 23rd, 2010, 03:17 AM
  #391
Registered
Bluevista's Avatar
Oh no!
What are you going to do for fun Erik!
Too cool.
Congratulations on a job well done, just the way I would of did it.
Doing your own bodywork is one of the things that seperates the men from the boys.
A man's man does his own paint.
The most manly men do Spies-Hecker paint jobs.
Can I have your autograph Erik?:
The fender to door gap looks a little big on the left side.
Old September 23rd, 2010, 04:38 AM
  #392
Registered Luser
ent72olds's Avatar
Well thanks Blue......I didn't notice that gap! Good thing I didn't put the woodgrain on yet! Should I do that now, or after it's painted!
Yeah, I couldn't sleep at all last night......not sure what I will do next! Maybe I'll forget this one, and start the next project! Seems I have a million of them at about 75% completion...some kind of mental block I have! I saw a '72 Vega Wagon, all original, clean with no plates on it at a gas station! Wonder if it's for sale? I will check into it...maybe take out the 4 banger, and put the 330 from my Vista in there......stay tuned!
Old September 23rd, 2010, 07:09 PM
  #393
Registered Luser
ent72olds's Avatar
OK....primed fenders tonight! They look mint!
For anyone interested, I did infact check out that Vega today! It's a '71 wagon, old lady owned, excellent all orig condition, mint black vinyl auto w/console interior, w/39K original miles....the service station guy says the lady is a customer, and can't drive anymore! I asked how much and his reply..."$3000...she's not in a hurry to sell!".....I laughed and said, "have a good day!"
Old September 25th, 2010, 08:23 AM
  #394
Govt slave
squirell's Avatar
Looking good Erik !
squirell is offline
Old October 4th, 2010, 09:04 PM
  #395
Registered Luser
ent72olds's Avatar
Work On Firewall!
Progress continues as we stripped 80% of the firewall and cowl...etched it, seam sealed it to match factory application(in other words,"sloppy"), sealed it, and painted it...wet on wet on wet....we also decided , since they were off, to paint the insides of the fenders satin black.
Old October 4th, 2010, 09:06 PM
  #396
Registered Luser
ent72olds's Avatar
More pics....
Old October 4th, 2010, 09:09 PM
  #397
Registered Luser
ent72olds's Avatar
In these pics, you can see the seam seal before I sealed and painted it...by the way, off to Hershey on Thursday!
Old October 25th, 2010, 04:38 AM
  #398
wagonman's Avatar
Great work. What method are using when you strip your panels to bare metal?Thanks.
E.
wagonman is offline
Old October 25th, 2010, 08:09 PM
  #399
Registered Luser
ent72olds's Avatar
E.
We stripped with 80grit using a DA (dual action sander) and an electric sander from home depot....
Old October 25th, 2010, 08:12 PM
  #400
Registered Luser
ent72olds's Avatar
Dash & Door Frames Painted!
I haven't had much time lately to work on this, but did find a few hours tonight! Prepped and painted the dash and tops of the door frames.....
Quick Reply: '70 Vista Cruiser Project
