1968 442 Gas Pedal for an Automatic
Old June 14th, 2011, 06:54 AM
Tom442's Avatar
So I am putting my car back together. I took it apart 10 years ago so... a few years back I remember taking the gas pedal assembly apart, bead blasted and powder coated the metal parts like the shaft and the bracket for the electric kick down switch. So I am putting it all together last night (I do have CSM, Fisher body manual and the assembly manual). The electric kickdown hits what looks to be another mounting point for a kickdown cable???To the best of my memory I may have acquired another pedal assembly? It not only has the throttle cable mount point...but another spot for what is probably a kick down cable? Doesnt need both the electric kickdown and a cable kickdown right??? My memory is failing me and not at a good time! Now where did I put the original pedal? This is an image of what pedal I am working with...
Tom442 is offline
Old June 16th, 2011, 02:59 AM
Yellowstatue's Avatar
It's probably a pedal for a '69 or '70 with a cable detent that you dont need...you just need the kickdown switch bracket for the 400...
Yellowstatue is offline
jensenracing77
April 20th, 2014 03:39 PM
rcktdoc
February 28th, 2014 08:37 AM
February 6th, 2012 10:14 AM
jensenracing77
February 7th, 2010 05:30 AM
64starfire
June 12th, 2009 07:43 AM
Quick Reply: 1968 442 Gas Pedal for an Automatic
