seatbelt question
Old June 7th, 2014, 05:41 PM
denf221's Avatar
seatbelt question
I have a 72 cutlass supreme, here is situation. I addressed this before but I don't think I explained the problem in enough detail. The front seat belts work fine but I don't think the rear seatbelts have been used in quite some time. the female end of all the rear seat belts are stuck to the point where I cannot adjust the belt to fit individual people. How can I loosen the belts so that they adjust easily without damaging/staining them?
denf221 is offline
Old June 7th, 2014, 09:29 PM
RandyS's Avatar
You will have to disassemble the female end and clean the smutz off of the serrated bar (or roller) to allow smooth movement of the webbing. They can be very stubborn to get apart, heavy screwdrivers usually do the trick.
RandyS is offline
Old June 8th, 2014, 11:50 AM
To disassemble them, pry the lower portion of tabs up on the rear of the buckle so they disengage from the lower buckle housing, then lift the cover. It will rotate forward and up to come off like a clam shell. The pic below shows the tabs. They are hard to pry so don't be afraid to use a bit of force on them.
Fun71 is online now
Old June 9th, 2014, 05:36 AM
denf221's Avatar
thanks
denf221 is offline
Old June 15th, 2014, 12:28 PM
denf221's Avatar
Hi was just looking at my belts, they say Hamill rcf-65 on housing, is this the same one you are referring to?
denf221 is offline
Old June 15th, 2014, 02:05 PM
denf221's Avatar
the female end is supposed to freely move back and forth correct? the only thing the button for is to disengage the buckle? I took the buckle apart per your instructions and took a tooth brush to the roller but the belt still doesn't move freely I think the belts are just too dry to move if I took them out to clean what would you recommend I soak them in to loosen them up without staining them?
denf221 is offline
Old June 15th, 2014, 04:12 PM
mrolds69's Avatar
The female end should move smoothly, but sometimes only if you bend it and touch or point the bottom side of the buckle towards or to the belt. The belt kind of locks in the normal position, you can pull it tighter and it will lock on your waist. But to loosen, you have to do what I said. It's a simple thing, but we are spoiled by auto retractors now. The belt itself also has to be supple and clean. If it's stiff then it won't move easily.
mrolds69 is offline
pfergy600
July 23rd, 2014 09:19 AM
denf221
June 15th, 2014 01:19 PM
bowtiebrad
March 6th, 2013 07:02 PM
bowtiebrad
February 3rd, 2013 09:59 PM
Wyze
March 13th, 2010 09:18 AM
Quick Reply: seatbelt question
