Shoulder Belts on 72 Convertible
Old August 9th, 2010, 10:19 AM
mhood's Avatar
I just figured out why there were so many seat belts in the back of my 72 cutlass convert. I assume the long ones attached high up under the side panels are shoulder belts for the front? If so I can't figure out where they are supposed to go, out through the open area around the convertible top?
mhood is offline
Old August 9th, 2010, 10:28 AM
Lady72nRob71's Avatar
There should be 3 sets, one set for three rear passengers.
The center one gets a linger belt, as there was no retractor.
If you have more, they were most likely installed by a previous owner.
A picture would be good to see.
72 Cutlass verts did not get shoulder belts from the factory, as far as I researched.
Lady72nRob71 is offline
Old August 9th, 2010, 10:53 AM
jeffreyalman's Avatar
at the very end of this thread there is mention made of 72 Cutlass convertible shoulder belts https://classicoldsmobile.com/forums...eat-belts.html
jeffreyalman is offline
Old August 9th, 2010, 11:38 AM
mhood's Avatar
the original sticker mentions shoulder belts. Here are some pictures
There are three sets in the back mounted to the floor
There are two very long ones mounted inside the side panels.
mhood is offline
Old August 9th, 2010, 11:59 AM
The three sets on the back are for the three back seat passengers. The two on the sides are the very rare but optionally available convertible shoulder belts. They do not go through the top mechanism, they simply go over the shoulder and attach to the mating part of the belt. Very cool and nice documentation of the attachments.
joe_padavano is online now
Old August 9th, 2010, 05:06 PM
Registered
Bluevista's Avatar
No extra female buckle ends in the front?
Some with those had a belt retainer on the side of the front seat too, I know Poncho did.
Bluevista is offline
Old August 9th, 2010, 05:58 PM
mhood's Avatar
there were extra buckles in the front that I thought the owner had put in by mistake. there are also holders at the bottom of the 'ashtray' panels.
I still am missing the female side to the passenger seatbelt. The one with the smaller buckle. Anyone know where to get this?
The real problem is that all the seatbelts in the back were sitting in a pool of fluid (hydralic? from the convert top pistons? ) I spent the day degreasing them and cleaning up under the seats. I can't seem to get the oil feeling off of the belts. any ideas?
mhood is offline
Old August 9th, 2010, 08:58 PM
stevengerard's Avatar
those are shoulder belts for the front occupants of a convertible. Female buckle in my car for the front occupants are the larger width deluxe seat belt (same size buckle as the back seat lap belts). You can ususally find a female end on ebay, may not be the exact length but close enough to work. You can always get it re-webbed as well. If you need I have the documentation for these for installation.
stevengerard is offline
Old August 9th, 2010, 11:56 PM
if you can get them off, best way is to soak in a bucket of hot water and some Dawn dishwashing liquid - believe it or not that is what they use to get oil off birds, scrub, rinse and repeat, changing water, always hot water
Old August 10th, 2010, 12:54 AM
Registered
Bluevista's Avatar
I used Dawn on mine too.
They use that stuff for bathing dogs at the grooming places too.
My older daughter worked for years as a dog groomer.
Worse than knowing how to work on cars, everybody wants her to work on their dogs for nothing.
Old August 16th, 2010, 08:19 AM
mhood's Avatar
thanks for all your help
Dawn worked great (a few hours and 2 bottles later)
Shoulder belts work good and are reasonbly comfortable
mhood is offline
Old August 16th, 2010, 08:21 AM
mhood's Avatar
photos of shoulder belts
mhood is offline
jcmoretti
July 11th, 2018 03:07 PM
KZ442
March 17th, 2015 04:58 PM
66-3X2 442
July 3rd, 2014 12:50 PM
woodie582
October 2nd, 2009 01:56 PM
stevengerard
September 26th, 2009 08:59 AM
Quick Reply: Shoulder Belts on 72 Convertible
