Oil pressure and guage issues
I have a 1979 H/O. The engine was rebuilt in the early 90's at just over 100k miles and I have about 11k on the rebuild. I store it every winter. Last year when I got it out. The gauges were all pegged but the oil pressure reads but lower than before. The pressure never seemed to vary much on use ever, before and after rebuild. It starts and stays at 20 where before it stayed above 30. I put a new sending unit, it has a wire, in with no change. The temp guage is maxed out and the volts are are bottomed out. The alternator puts out 14+v and the battery tester with load says strong. I have traced out the wires, looked for bad grounds, checked fuses...What alarms me the most is the lower than normal oil pressure.
The gauge setup in this cars is notorious for being faulty, Look out for a melted, battered printed circuit board. The Parts Place sells re-pop printed circuit boards, I have one in my 79 H/O as well as my blue 79 Calais and they cured alot of ills with these gauges. Or, you can possibly have the gauges sent out to be recalibrated but I'd examine the printed circuit board first. You may be shocked at what you see when you take a look at it.
I had the same issue with the 79 H/O I just bought a few months back. I ordered a replacement circuit board, swapped it out, replaced all the bulb and bulb holders and tightened all the nuts on the back of the cluster. I also bent out the harness pins that connect to the cluster.
I now have all the gauges reading properly. It was a cheap and easy fix, needed and well worth the money.
Well done. Classic G-body Garage has a really great 20 minute video on re-doing a 79 Cutlass gauge pod. I used it both times I re-did mine, it also assists with keeping those pesky bulbs lit.
One thing you might consider. It is a matter of taste though. Replace all the pod bulbs (194, 168, 161) with matching number LED bulbs. The brand I would recommend is Sylvannia cool white bulbs. Not cheap, but the key here is these bulbs do not throw anything near the heat given off by the conventional bulbs. Therefore they will not melt the printed circuit board or the pale green pod. Anyone who has done this job knows the headache of getting several of these bulb sockets out of the pod, especially the upper corner tach side. Sometimes you can't get them back in once they are removed, due to the pod melting. I used LED bulbs in my 79 H/O. While not original, they are brighter and they do dim somewhat. If your pod is badly burned, I'd recommend attempting to find a gauge pod wherein the is a tach delete plate. No bulb was placed in tif the tach was not ordered and that socket hole should be in mint condition.
You will find the conventional bulb probably burned your H/O shifter plate socket hole, so badly the bulb & socket may be held in there with black tape. This will cease with the LED bulb.
You are correct, the printed circuit board is located on the back of the instrument cluster. You'd need to remove most everything attached to it to get at it. I've done it so many times I can get through it fairly quickly, but take your time, alot of stuff can break along the way, and the way back. If you have cruise control you can disconnect the upper speedometer cable where it attaches to the cruise control unit, making it easier to remove the speedometer from the cluster by removing the 2 bolts, pulling it out a bit and then depressing the clip on the back of the speedometer head.
You will really benefit from watching the G-Body Garage video, it's a must see before doing this job. Avoid new gauges, if yours work properly you are a leg up on getting this job done right.
Man, that really peeved me when I installed an NOS H/O shifter plate on my console only to have that bulb burn right through the socket within a dang half hour of having it installed! I wish LED bulbs were around when I initially put it in.
I think the LED's look so good in my 79 H/O, I just may also convert to LED in my 79 Calais.
I repainted my shifter plate this weekend and did notice the housing was severely melted. I just left the assembly out as it's not really necessary here anyway.
