Air cleaner
Old August 27th, 2009, 01:58 PM
pureplaya442's Avatar
Air cleaner
Does anybody know if anybody reproduces the air cleaner for the 69 hurst olds? I heard there is one person that does this, but i dont know if it's true or not.
pureplaya442 is offline
Old August 27th, 2009, 02:04 PM
If you mean the "top can" the answer is Yes.
Call Bob Anderson in Tampa Florida 813-932-4611
The bottom of the air cleaner is just a 442 base with 5 holes drilled in it.
Here's the skinny
http://members.***.net/witrob/scoop/scoop.html
Jamesbo is offline
Old August 27th, 2009, 03:36 PM
666 the legend's Avatar
Here's the skinny
..So..?? I just need to get a 69 Cutlass air cleaner base and drill some holes huh..??
666 the legend is offline
Old August 28th, 2009, 04:03 AM
air cleaner base
Close you need a 69 442 air cleaner base.
The top can simpily slides down into the base. You will also need a lid for the air filter that is smaller than the base. The bad news is "correct ones" are tuff to find, the good news is many smaller aftermarket lids will work [although they won't be correct] so Don't take apart your air cleaner at shows.
https://classicoldsmobile.com/forums...r-cleaner.html
But I recently learned here [Thanks to Wmachine] that all 69 air cleaner bases are not created equal.
Check this out to discover the gradations betwix a 69 442 and a regular air cleaner base.
https://classicoldsmobile.com/forums...-base-red.html
Jamesbo is offline
Old August 28th, 2009, 06:03 AM
Hey thanks man, off hand do you know what he's charging?
Old August 28th, 2009, 07:41 AM
Are you itting down?
Last I heard it was $1,600.
Jamesbo is offline
Old August 28th, 2009, 09:44 AM
Wow.
In 1981 I bought my whole 69 H/O for $2,000 (from a seller in beautiful downtown Burbank). It was missing the original intake, carb, air cleaner, and outside mirrors. Later in the mid-1980s, I found and bought a set of exactly those parts (correct intake, carb, air cleaner top, and outside mirrors) for $600 (also from a seller in SoCal). I always wondered if those were the original parts from my car.
joe_padavano is offline
Old August 28th, 2009, 08:56 PM
fizzy55's Avatar
i have an air cleaner top and flapper door that i made out of fiberglass a long time ago that may be available. when it's installed you can't tell it's not metal
fizzy55 is offline
Old September 14th, 2009, 09:25 PM
HurstOlds1775's Avatar
Do you still have that fiberglass one for sale? Any pictures of it.
HurstOlds1775 is offline
Old December 21st, 2015, 07:51 AM
camshaw's Avatar
an old thread for sure, but has anybody here received one of bobs HO tops? both my HO cars are missing them and Ive been saving my pennies to buy them, I was just wondering if anybody has any pics? thanks,cam
camshaw is offline
Old December 21st, 2015, 10:00 AM
Octania's Avatar
I thought W-Tony was making the top parts. Then stopped?
I have one air cleaner base for such a project, the OS code 442 unit.
The intake is easy, I have 3 of them in the basement, almost made.
Octania is offline
Old December 21st, 2015, 11:16 AM
rr69ho's Avatar
Hey Chris, the base for the H/O air cleaner is NOT the same as the 442.
Due to the PCV in the intake, the base had outlets for each valve cover and the originals did not have holes drilled in the bottom like the 70 and up bases did.
rr69ho is offline
Old December 21st, 2015, 04:37 PM
geardoc66's Avatar
I have one of the fiberglass reproduction tops I used for one season that I will sell. PM me of you are interested
geardoc66 is offline
Old December 22nd, 2015, 09:53 AM
Octania's Avatar
Ah, I see
I was going by post #2 info, which may be inaccurate:
"The bottom of the air cleaner is just a 442 base with 5 holes drilled in it.
Here's the skinny
http://members.***.net/witrob/scoop/scoop.html "
Octania is offline
69CutlassAlex
December 2nd, 2011 08:01 AM
WTony
July 3rd, 2010 11:12 AM
dan1s
April 17th, 2010 08:14 AM
StickW31
February 25th, 2010 01:14 PM
Viper
August 13th, 2008 10:58 AM
Quick Reply: Air cleaner
