started pulling 300 amps?!
Old February 24th, 2015, 10:06 AM
major noob
billmerbach's Avatar
Exclamation started pulling 300 amps?!
While I'm waiting g on my carb calibration kit to come in the mail I need help I had a starting and electrical systems test done the other week back and my starter is pulling 300 amps to start everything else is perfect but this isn't good for the starter or battery how can I correct this
billmerbach is offline
Old February 24th, 2015, 10:18 AM
300A doesn't sound high to me, but I'm not the authority.
Ask Stellar - He's the authority.
What's your compression ratio? What viscosity oil are you using?
MDchanic is offline
Old February 24th, 2015, 10:54 AM
68_convert's Avatar
Does it continuously draw 300 amps or is it the first second or so because that is normal.
68_convert is offline
Old February 24th, 2015, 12:42 PM
major noob
She never told me she just said on startup so I'm assuming that'd the only time its pulling that much and MD I have around 9.5.1 compression and 10w30 but on that note I notice while cruising it is 25 to 40psi but when ideling the psi shoots up to 50 to 55 psi is that normal
Old February 24th, 2015, 01:12 PM
Originally Posted by billmerbach
... while cruising it is 25 to 40psi but when ideling the psi shoots up to 50 to 55 psi is that normal
Okay, that's just weird. Should be the opposite. I have no explanation.
As for the current, 300A doesn't sound out of line to me (I think 150-300 is in the general ballpark).
Why did the person testing it say it was high?
MDchanic is offline
Old February 24th, 2015, 01:19 PM
major noob
Staff change at my favorite parts store so its all full of newbies and idk she just said it was high.....about the oil don't say weird I don't need to hear that right now its been problem after problem please no more problems lol
Old February 24th, 2015, 01:39 PM
CutlassDad's Avatar
The components tester is there to sell electrical components!
A "breakaway" current of 300 amps or so sounds about right, if memory serves from my diesel engine days.
CutlassDad is offline
Old February 24th, 2015, 01:55 PM
300amps is not out of the question for a starter. If it starts fine and you don't see smoke, your good to go.
Remember all electrical components are made of smoke, when they crack apart and let the smoke out, there no good any more.
Is your oil pressure gauge mechanical or electrical Bill?
oldcutlass is online now
Old February 24th, 2015, 02:05 PM
major noob
No smoke an using mechanical gauge and when. I crank up got about 50 to 55 when it accelerates it rises and drops with the transmission shift pattern but it ultimately cruises at 25 to 40 an 50 to 55 at idle I'm thinking k and oil flush and oil treatment
Old February 24th, 2015, 02:38 PM
Your gauge has no wires to it, it works off a plastic or metal tube?
Old February 24th, 2015, 02:44 PM
major noob
Yup plastic see through tubing leading to the gauge
Old February 24th, 2015, 02:57 PM
I'm with Eric, got no explanation.
Old February 24th, 2015, 03:00 PM
major noob
Would air in the gauge line be a cause no matter how many times I bleed it it gets air in the line
Old February 24th, 2015, 03:01 PM
It will always get air back in the line because it's not a closed system.
Old February 24th, 2015, 03:03 PM
Yeah, if the air bubbles bother you, get copper tubing - then you won't be able to see it.
MDchanic is offline
Old February 24th, 2015, 03:05 PM
major noob
Maybe I'm also over analyzing everything I'll do an oil flush next chance I get and put some additives and Lucas stabilizer in there
Old February 24th, 2015, 03:10 PM
I would not do a flush, just change the oil after a 1000 miles and then resume the normal change schedule. Stay away from the additives and enjoy.
Old February 25th, 2015, 04:28 AM
Oldsdruid
rocketraider's Avatar
Get rid of that plastic tubing too and go with copper. You'll need to put a vibration loop in the copper tubing too, to allow for engine vibration.
That pressure reading is weird. Could be a bad gage but a mechanical oil pressure gage is pretty simple, not much to go wrong.
The Lucas stabilizer treatment is about as good as there is but if the engine is quiet and not using much oil, I'd stick with 10W30, no additives.
rocketraider is offline
Old February 25th, 2015, 02:32 PM
major noob
Forgot to look at my oil psi while having fun today but I've been reading bout pinging how easy is it to tell cause I really don't want to mess up my engine
Old February 27th, 2015, 02:52 AM
'87 Delta 88 Royale
rustyroger's Avatar
You will hear pinging. Typically if you give the car some right foot at low revs you will hear a diesel type rattle under the hood. If you can hear it you need to address the problem, it can do serious damage to your engine.
It could be as simple as using higher octane fuel, or retarding the ignition a little, but if the engine is pinging fix it or it will cost you in the long term.
A spike of 300 amps when the starter engages is normal, electric motors are at peak torque when stalled, in other words draw most current getting moving.
I'm as baffled as anyone by your weird oil pressure readings, particularly as you haven't mentioned any other problems with the engine.
Roger.
rustyroger is offline
Old February 27th, 2015, 07:31 AM
major noob
I honestly don't hear anything that sounds odd I won't run her much till I get my tab just to be safe
jensenracing77
November 6th, 2022 09:52 PM
HAFROD
October 1st, 2017 08:39 PM
atkinsom
May 26th, 2013 05:52 PM
greyghost
July 11th, 2009 05:17 PM
CreekBandDad
July 15th, 2007 02:01 PM
Quick Reply: started pulling 300 amps?!
