Smoke or steam dash vent issue
Old February 6th, 2017, 11:23 AM
Jimoldsfan's Avatar
I was wondering if anyone has any ideas what the problem is with my 71' Cutlass. Yesterday when driving my car for the first time in several months, I noticed what seemed like a very faint smell of Antifreeze. After driving about a mile (AC was off but vent and fan was on) I noticed that the windshield as well as the side windows were starting to steam up. I turned the defroster on but it did not seem to help. After a short time (about another mile) steam or smoke stated coming out of the vent pipes. I am sure it was steam though, no burn smell but not really smelling like antifreeze either. It was very White in color.
Does this sound like a heater core going south? I looked under the hood and no visible signs of steam or leaking at any of the hoses. Also no moisture around or below the heater core inside the car. Everything was dry there. This is the first time I have ever notice this issue.
Any ideas are greatly appreciated.
Jim
Jimoldsfan is offline
Old February 6th, 2017, 11:30 AM
2blu442's Avatar
Yes, it sounds like your heater core may be leaking. Any dampness in the carpet on the passenger side floorboard, under the heater box?
2blu442 is online now
Old February 6th, 2017, 11:40 AM
m371961's Avatar
Classic heater core symptom.
m371961 is offline
Old February 6th, 2017, 12:13 PM
Ayup.
Make an appointment with your chiropractor now.
MDchanic is offline
Old February 6th, 2017, 01:41 PM
I agree, classic heater core leak symptoms.
Most times that my heater core has started leaking there would be a spot of condensation on the inside of the windshield above the defrost vents.
Fun71 is offline
Old February 6th, 2017, 04:13 PM
Definitely the heater core. If you don't want to replace it for now just remove the hose from the manifold and connect the one from the water pump to the manifold. It will be bypassed and you can do the repair at your convenience and still drive the car.
oldcutlass is online now
Old February 6th, 2017, 04:43 PM
That isn't always easy to do as one hose/fitting is 5/8" and the other is 3/4".
Fun71 is offline
Old February 6th, 2017, 04:48 PM
MDchanic is offline
Old February 7th, 2017, 11:38 AM
'87 Delta 88 Royale
rustyroger's Avatar
A plumbers reducing bush will sort that out. Your local plumbers supply shop should have a choice for you.
Roger.
rustyroger is offline
Old February 10th, 2017, 09:06 AM
Tedd Thompson's Avatar
Or you can put the end that is small in boiling water for 30 seconds and usually they will stretch enough to get it on so a clamp will hold.... Tedd
Tedd Thompson is offline
Old February 10th, 2017, 09:18 AM
Hookers under Hood
76olds's Avatar
Originally Posted by MDchanic
Ayup.
Hahahaahhh yeah!! Lmao! Eric's re and re'd a heater core before.
Put-r-ther!!
76olds is offline
Old February 14th, 2017, 12:29 PM
Jimoldsfan's Avatar
Thank you everyone for your help. I think I will do the by-pass alternative for a temporary quick fix. Jim
Old February 14th, 2017, 04:56 PM
For a band-aide fix sometimes a shot of radiator stop leak will get you home or through the snow storm, don't bet your life on it though.... Tedd
jensenracing77
May 26th, 2015 04:09 AM
plonka
December 12th, 2013 10:38 AM
Delta88conv455
August 8th, 2013 07:31 PM
gearheads78
Site Suggestions
20
January 30th, 2009 04:27 PM
TheRuss
June 5th, 2007 11:01 AM
Quick Reply: Smoke or steam dash vent issue
