91 cutlass supreme 3.1 died and won't start
So I have a 91 cutlass supreme with the 3.1... well driving home from work one night it died on me all I heard was poof (like a hose blowing off) and the car died on me when using turn the key the car turns over but won't start at all... does anyone have any ideas at all what it could be or what I should be looking for... also before this happened every now and then when I'd go to start the car it would start and then die if I didn't tap the gas pedal but wouldn't always do it any ideas would help a lot I prefer working in my own car as much as I can thanks
Based on your description of the issue, I can say with all confidence, its broke...
In order for anyone to give you further help you need to troubleshoot and answer Patricks question to narrow it down a bit. Is it fuel or spark?
91 olds
Had a friend look at it last night it turns over but won't start he said he thinks I might of blew a vacuum hose off gonna try the starter fluid and see if it starts this weekend
Last edited by citycowboy87; December 7th, 2016 at 12:51 PM. Reason: need to add more
Since you need the engine running to create vacuum, don't see how that could prevent the engine from at least starting... If it would start and then stall, I could see a possible vacuum problem...
