looking for part# for alt,starter,77 cutlass
Old October 23rd, 2016, 08:03 AM
goatman73's Avatar
was trying to see if anyone has the numbers for the alt and starter for my 77 442,i am replacing them and want to make sure they are not been replaced.if orig I will rebuild them to keep orig to car, thanks.
goatman73 is offline
Old October 23rd, 2016, 08:49 AM
Well, which engine? The starters will be different.
What options? The alternator will be different depending on option, especially A/C or not.
joe_padavano is offline
Old October 23rd, 2016, 10:21 AM
svnt442's Avatar
403 from what he posted in another thread.
svnt442 is offline
Old October 23rd, 2016, 10:22 AM
svnt442's Avatar
And I'd say it has A/C as well..
svnt442 is offline
Old October 23rd, 2016, 11:33 AM
goatman73's Avatar
yes it has the 403,ps,pdb,ac hood and trunk light that's about it for options thanks.
Old October 23rd, 2016, 11:54 AM
macrover's Avatar
I'm totally with you on wanting to rebuild the originals, if they're still on the car.
To get you started and based on the tidbit I can slightly see in your photos, IIRC, you may have...
#1102843 or #1102844 (code "JC" or "JD") for your Generator (alternator). There are a couple other "option based" numbers and codes that could be on the car but lets start with these two for now.
Your starter could be #1108794, #1109022, #1109026, or #119072. Depending on when your car was built, these numbers could have been changed or superseded.
On your build sheet, check boxes 30 and 31 to see if they have two letter codes in each of them. Although, box 30 probably has two ** in it. 50/50 shot on a code being there.
Box 31 may have code JC or JD in it. Whichever code is in the box, it will be stamped on top of the generator (alternator) if it hasn't faded off or been changed.
I'll double check my literature when I get home.
For now, I hope this helps.
macrover is offline
Old October 23rd, 2016, 12:09 PM
goatman73's Avatar
k thanks,doesnt look like they are originals. my alt is 110796 fg 7m5, and starter is 1108781 6c10 7, box 30 has no code but 31 has the jc thanks.
Old October 23rd, 2016, 12:20 PM
macrover's Avatar
Okay, let me check those numbers when I get home and see if I can decode the dates and what I can find out on them.
Your alternator is #110796? Is there a number missing? Is it a 61amp alternator?
macrover is offline
Old October 23rd, 2016, 01:35 PM
goatman73's Avatar
yea sorry its 1100796 and yes its 61 amp alt thanks.
Old October 23rd, 2016, 08:34 PM
macrover's Avatar
I'm researching the numbers you provided. When was your car built?
Have a photo of your trim tag?
macrover is offline
Old October 23rd, 2016, 09:49 PM
goatman73's Avatar
here a pic of my trim tag
Old October 24th, 2016, 04:09 AM
RocketDevo's Avatar
macrover has the right numbers, but to narrow it down the 61 amp 1102843 is the alternator number you need. the 1102844 applies if you have a heated back glass. The 1108794 starter is what would have come in your car originally. The 1100796 alt you have is correct for 1968 Chevelle/ Malibu's.
RocketDevo is offline
Old October 24th, 2016, 12:14 PM
goatman73's Avatar
k thanks guys,also was wanting to verify trans but couldnt see numbers on it ,where should they be?i know on pontiacs its stamped in case or has tag on older ones.
Old October 24th, 2016, 06:15 PM
macrover's Avatar
You're welcome. Thanks for the trim tag photo, I wanted to check your build date. Looks like it was built the second week of November in '76.
RocketDevo, thanks for the input and you are correct. You got to this before I could.
Yes, the 1102844 is for heated glass, A/C, and heavy duty cooling. Based on his photos, I noticed the car had A/C and didn't have the heated glass. It was/is not known if it's the original back window or not. Additionally, heavy duty cooling was in question as well.
Before it was known which code was on the build sheet, I simply posted both numbers and the corresponding codes to give him an idea of which generator/alternator it could have been, if it was original to the car.
Regarding the transmission numbers, yes, the VIN derivative is stamped on the driver side of the case (lower middle, near the shift bracket). The code for the transmission type, probably "LMxxxxxx", is stamped on the governor cover on the driver side of the transmission as well.
Does your dealer check sheet have the transmission number(s) on it?
macrover is offline
Old October 24th, 2016, 09:09 PM
goatman73's Avatar
car does have hd cooling,check sheat doesn't have any numbers like that but build sheet under trans has olm*in box.no sighns of rear defrost, no switches present for defrost.
Old January 16th, 2023, 01:19 PM
Pecosbill7's Avatar
I have a 1102843 core that I took off my 76 Cutlass years ago if you want it. Cover the postage and whatever you feel is fair for the alternator.
Pecosbill7 is offline
roberer
September 22nd, 2015 09:36 AM
Olds1971
October 4th, 2012 05:09 PM
1970_442
January 20th, 2012 03:48 PM
sammieolds
August 29th, 2010 03:20 PM
1970_442
July 8th, 2010 05:42 PM
Quick Reply: looking for part# for alt,starter,77 cutlass
