Windshield wiper linkage restoration
Old June 20th, 2017, 07:59 PM
servexcell's Avatar
Is the parts available to restore the linkages. has anyone done so?
Thanks Bruce
servexcell is offline
Old June 20th, 2017, 08:46 PM
Phantom Phixer
Charlie Jones's Avatar
Here's one ;
http://www.wiperman.com/
Charlie Jones is offline
Old June 21st, 2017, 07:01 AM
oldspackrat's Avatar
I have several good 1968-72 wiper transmissions here in Indy.
Call me?
Scott
317-727-7041
oldspackrat is offline
Old June 21st, 2017, 02:57 PM
oddball's Avatar
You can mostly disassemble, clean and lube the parts. Some of the joints can't be disassembled, but you can inject lube. If a part is completely worn out then you may be best off buying a better original unit.
oddball is offline
Old July 4th, 2017, 09:14 PM
servexcell's Avatar
It seems like the joints are a ball and socket type,They are bolted and i think they have copper sleeves. Does anyone know were to get parts
thanks Bruce
Old July 4th, 2017, 11:08 PM
Phantom Phixer
thanks Bruce
Bruce , I can only assume that we are talking about a '68 Cutlass or 442 ?
This wiper linkage was crimped together at the joints , and was serviced only as a complete assembly . There was a left and right side . Some models had recessed park {disappearing} wipers. The left side had a different assembly.
Everything from the round part that the wiper arm attaches to , down to the wiper motor .
I found the following;
I found the part numbers here;
http://wildaboutcarsonline.com/membe...sher_Parts.pdf
4918758 for RH side
4918620 for LH side (without recessed park)
Then I took those numbers to GM partswiki ;
http://www.gmpartswiki.com/getpage?pageid=50762
and found out that that those same parts also fit '68 thru 72 Chevelle .
I googled '68 Chevelle wiper linkage and found this ;
http://www.jegs.com/i/Performance-Tr...yABEgKasPD_BwE
Old July 5th, 2017, 06:48 AM
I have several complete wiper transmission assemblies, $35.00 plus shipping.
Old August 24th, 2017, 05:29 PM
servexcell's Avatar
Sorry for the belated response guys. Reaaly appreciate the help. I think you can maybe pirchase bushings for the linkage.
Bruce
507OLDS
March 19th, 2014 08:17 PM
STLCRZY
November 4th, 2013 03:22 PM
miked
August 5th, 2013 03:15 PM
ztim
December 23rd, 2006 04:53 AM
Quick Reply: Windshield wiper linkage restoration
