Upper and lower radiator hose springs
Anybody know where I can find the springs for the upper and lower radiator hoses or where I can find the hoses with them already installed? This is for a 68' Rocket 350 cutlass. Thanks.
@ Eric, my upper radiator hose did have a spring in it (maybe wasn't supposed to). Anyway the springs in both the upper and lower radiator hoses were all rusty and in numerous pieces. I'm not sure how old the parts on the engine are in relation to the actual year of the car (68') as it's not the original motor, but it is an Olds Rocket 350, which is what was factory. I appreciate the quick replies guys. I'll just install my new Goodyear radiator hoses and clamps without any springs. Thanks again!
Well, for whatever it's worth, the water pump pulls the water from the radiator into the pump, which can collapse the lower hose, bit the upper hose, which carries hot water from the engine to the radiator, is generally under pressure and will not collapse.
I know when I rev my 455 at the carb, my bottom hose collapses. I purchased that hose from Autozone not too loong ago. Maybe I'll try N n n n Nappa know how. next. he he he
w-30dreamin
March 29th, 2010 06:32 PM
