tilt column
tilt column
I have a tilt column I want to install in 69 442 convert, the bracket for transmission lock rod needs to be in a diferrent position .can it be done? the column is for floor shift automatic, it fits in car very well otherwise .
There is no difference in the backdrive linkage between a tilt and non-tilt column. I'm guessing that you have a 1973-up column, not a correct 69-72 column.
If by "bracket" you mean the backdrive lever that comes out of the base of the column, the short answer is no. That lever is welded to the bottom of the shift tube that runs concentrically inside the column. The only way to relocate the lever is to change the shift tube or cut it off and re-weld it.
67442nut
April 4th, 2016 11:55 AM
Bitburger
December 30th, 2012 04:49 PM
