1968 Standard vs Tilt Column Question
I've gone back to working on my '68 Cutlass. I was lucky enough to acquire a tilt column for my car this past winter. I just got it painted and was transferring the hardware from my standard column when I noticed a couple of differences.
Tilt column has what looks to be a factory square hole in it.
Standard column doesn't.
Does anyone know what the hole on the tilt column is there for?
Standard column has a spring near the bottom inside
Tilt column doesn't seem to have this
Anyone know why?
Thanks,
Anyone know why?
Thanks,
The square hole is for a column shift indicator for an automatic, does the top of the column have a spot for a shift handle. As for the spring at the bottom not sure hopefully someone can chime in for that.
Olds1968, no, it is not for a column selector. Maybe it was changed over at some point and a floor selector bowl was put on it. It makes sense that the hole is for that though. Thanks for the info.
Joe, thanks for the tip on the retainer. I will check them out.
starfire
December 9th, 2021 08:21 PM
Rocketbrian
October 2nd, 2013 10:18 AM
Bitburger
December 30th, 2012 04:49 PM
ELECMAN
January 22nd, 2012 01:49 PM
ros6872
February 24th, 2010 05:50 PM
