LED Headlights
LED Headlights
I picked up these for my headlight conversion on the Delta:
http://www.carid.com/universal-led-l...s-3659407.html And I also picked up the H7 for the high beams. $17.95 a bulb
Use 5 watts and the H7 use 10 watts. I still picked up "H4 heavy duty wiring harness" and a pair for the H7 on NewEgg.com for a total of $21.90 shipped to my door.
It's not a conversion harness, but I can do that myself fairly easy and not have to hack up my factory wiring.
I'll give an update when it happens
I am interested in knowing how they work also. I just installed an LED bulb in my 6 cell Maglite that is 1000 lumens. it is incredible how bright it is but haven't seen anything like it for cars yet. I have been interested in LED technology for a long time but just now starting to play with it.
I did the swap and I was very disappointed
The two pics on the bottom tell the story:
First one is the LED bulb on the pass side and the regular factroy style headlight on the driver's side. The other pic is the high beam H1 bulb and the LED H4 bulb which is supposed to be brighter than the H1.
In the process of returning the LED bulbs for a refund. I will have before and after night pics of the regular bulbs and factory headlights to compare. Don't have a night shot of the new bulbs yet.
I will also write up a quick "How-to" on how to use OE 55w H4 bulbs on a 35w system. Still needs beta testing before I decide if it's safe for my wiring. If not, there are 35w H4 bulbs out there. You just have to buy them online
The LED technology is already here to do headlights and do it well, but expect a few hundred bucks though.
When I worked at TI, I designed up an evaluation board that drove five Osram Golden Dragon LEDs, about 1 watt through each. Anyone can buy 'em, too!
https://estore.ti.com/TPS61500EVM-36...ule-P1502.aspx
With some narrow flood lenses ever the LEDs, the board was just as bright as a high beam car headlight, or possibly brighter, and would run off 4 AA batteries or 12VDC. The wholesale cost on the LEDs alone was 30 bucks, so high brightness is not cheap. Add in PCB cost, driver IC, heatsink, and other parts and it is an easy $200 each bulb. Markup on stuff like this is super high, too.
Eventually the price will decrease but until then, halogen replacements work great.
