high resolution wiring diagram
Old May 24th, 2014, 11:25 PM
Dan P.
FSTGeek's Avatar
Post high resolution wiring diagram
Does anyone have a source for a readable wiring diagram for a 67 Delmont? I've found several low resolution ones but the tiny text is just unreadable blurs.
Or, for my current question that I'm squinting at the diagram for right now... does the delmont have a ballast resistor or a resistive wire going to the coil? If it has the ballast resistor, where is it?
Or, even more to the point, I'm getting rid of the points and using a Pertronix ignitor III, do you NEED to run the full 12 volts to it or will the 7 volts at the coil work? I'm asking because Pertronix "RECOMMENDS" bypassing the resistor for "optimum performance". They don't say "you must"...
Still would love to have a hires wiring diagram even if the other questions are answered.
Thanks for all your help.
Dan
FSTGeek is offline
Old May 25th, 2014, 01:42 PM
Well, the highest resolution wiring diagram you will find is in the 1967 Chassis Service Manual - the original, paper one. You can purchase used originals on ebay for about $15.
It's a resistor wire from the bulkhead connector to the coil.
joe_padavano is offline
Old May 26th, 2014, 08:58 AM
Dan P.
FSTGeek's Avatar
Thanks Joe,
I had been using the ones available on the Web then broke down and bought the service manual on CD hoping it was higher resolution.
I guess I'll pick up the books. I much prefer holding a book in my hand anyway.
Thanks again
Dan
FSTGeek is offline
illumined
December 30th, 2014 07:38 PM
Macadoo
June 24th, 2014 05:36 PM
smcurro
Paint
January 29th, 2012 02:31 PM
Col Wickham
January 1st, 2010 05:31 PM
oldzy
September 10th, 2009 05:23 AM
Quick Reply: high resolution wiring diagram
