Engine oil Brand
Old September 16th, 2015, 08:22 AM
442fanatic's Avatar
Engine oil Brand
Am nearing the finish line with my 76 cutlass 442 - with the 455 olds rocket.
I have overhauled the engine and am curious as to what people are using for oil. Many forums are pushing the high ZDDP oils for the flat tappet engines.
I do not want to use Race oil like AMS or the racing Valvoline.
Heard Shell Rotella T3 for diesel engines is still high in ZDDP.
I live in the midwest, 10w30 or 15w40?
Alex
442fanatic is offline
Old September 16th, 2015, 09:03 AM
Beer Connoisseur
70cutty's Avatar
you will get 100 different opinions from 100 different people
70cutty is offline
Old September 16th, 2015, 09:21 AM
jaunty75's Avatar
I'd make that 200 opinions from 100 people!
I put whatever's-on-sale 10W30 or 10W40 plus a container of STP Oil Treatment for the ZDDP in my '73 Custom Cruiser back when I owned it (sold it last December). Never had a problem.
People seem to want to treat these engines these days as though they're made out of eggshells when all you did back in the day when the engine needed a quart of oil was put in a can of the correct weight chosen from whatever was on the rack next to the gas pumps.
I think the key to long life in these engines is more changing the oil frequently than it is to use the latest synthetic (which did not exist back when these engines were new) that cost $10 a quart.
jaunty75 is offline
Old September 16th, 2015, 01:53 PM
wr1970's Avatar
The reason is the break in for the cam has to have the heavy metal in it.Why because if you don't you can ruin the cam.After motor is broke in use what you want. Synthetic would be okay if that is what you want after break in.JMO
wr1970 is offline
Old September 17th, 2015, 02:11 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
I like Shell Rotella T, either 10/40 or 15/40 for an older engine and Prolong engine additive. I also use WIX, NAPA Gold, Racore or Baldwin filters on all my muscle cars. When I can find a dealer I really like Schaeffer products. Schaeffer 10W40 or 15W40, no additive required. Google Schaeffer oil. They make all sorts of lubricants. Their grease is superior to most. I have first hand knowledge of how well all their products work, same for the Prolong. Why not spend a little more for piece of mind. Its cheap insurance. I run Mobil 1, 15K extended and the highest quality filter available in my F250 daily driver with the matching extended life Wix Motorcrtaft NAPA gold filters etc....Cheap filters n oil not for me.
droldsmorland is offline
Old September 17th, 2015, 03:06 PM
Tedd Thompson's Avatar
I'm a Rotella T user but not radical in my choice, other brands would probably work as well. I feel that the break in is the most important time for a ZDDP rich oil after that most ant quality brand will do just fine...... Tedd
Tedd Thompson is offline
GEARMAN69
January 20th, 2015 04:52 AM
72Blazerod
January 1st, 2015 10:04 AM
442craig
July 1st, 2014 05:05 PM
Nickthefish
January 27th, 2013 10:47 AM
Quick Reply: Engine oil Brand
