Aluminum Radiator Repair
The bolt for my overflow tank has been rubbing against the aluminum radiator. It did bore a decent indentation, but it does not leak. Only noticed it while doing some other service.
Even though it's not leaking, I'd like to be proactive and reinforce the area, my mind goes to a JB Weld (or similar) product.
Any suggestions?
Any suggestions?
^^^THIS^^^
TIG welding is the proper way to repair aluminum. Either that or just leave well enough alone and cut a rubber insulator to go between the bolt and your radiator. I've used heater hose before that way by cutting it open.
Thanks for the comments.
It's the passenger side tank that has the damage. I've send JB Weld a message to see what they suggest. I'll probably just pull the radiator and have a local shop filler weld it. Years ago I had them pinch the aux heater hose nipple shut and weld it, since I don't trust the rubber block off caps. Weld looked good and has held up fine, hopefully the same guy still works there.
Northern Radiator, specifically 205055. https://www.northernradiator.com/Product/205055
Can be found a bit over $300
