1970 455 Ignition Coil Wiring
Old April 10th, 2014, 09:22 AM
70 Cutlass SX
pcard's Avatar
I was looking at the wiring diagramme in my Service Manual and noticed that the wiring for my Ignition Coil does not match what the manual says it should be.
Attached is a diagramme of my coil, and three photos.
The manual has the yellow from the starter going to the same post as the ignition resistor wire, and the black primary lead wire going to the other post.
You can see that mine is very different.
How can this work?
Also, I have an extra black wire from the engine harness with going to the same post at my yellow. What is that for?
File Type: pdf
pcard is offline
Old April 10th, 2014, 09:52 AM
Octania's Avatar
Looks OK to me, for something converted to w/o pts.
does it not run?
Octania is offline
Old April 10th, 2014, 09:58 AM
It should look like this, the condenser on the coil goes to coil +, your electronic ignition may or may not use the resistance wire.
oldcutlass is online now
Old April 10th, 2014, 10:51 AM
70 Cutlass SX
pcard's Avatar
I think I was all mixed up on what wires are what.
The black wire coming off the positive is the ignition wire (part of the harness), along with the yellow from the starter (also part of the harness).
The brown wire coming off the negative terminal, connected to the braided/shielded wire is the aftermarket tach wire.
Sorry for the confusion guys - I'll take a nap and feel better.
pcard is offline
Old April 10th, 2014, 12:14 PM
The condenser on the coil goes to the positive post for radio noise suppression. It looks like it's on the negative side.
Old April 10th, 2014, 06:13 PM
70 Cutlass SX
pcard's Avatar
Eric! It certainly isn't doing any good sitting at the bottom of the well (energy wise).
Thanks, I feel so sheepish not seeing that.
It is a good thing I have a recent aftermarket radio with built in filters. I am missing the condenser on the fan blower as well as the regulator, so basically have been running with no original-specified noise suppression.
De soun's still soun' well! (Bermudian vernacular for the radio still works well- you have to say it out aloud phonetically to see the meaning).
thanks Mate.
pcard is offline
Old April 10th, 2014, 08:55 PM
Hahaha, it does make sense when you say it out loud. You don't need the filters unless it's needin filterin.
ROCKET VAPOR
December 28th, 2013 08:53 PM
CutLS
August 5th, 2012 08:09 PM
cisco88
January 27th, 2009 09:28 AM
1FSTLS1
December 20th, 2008 05:45 AM
68conv455
February 20th, 2008 02:36 AM
Quick Reply: 1970 455 Ignition Coil Wiring
