Ignition coil ?
Old January 27th, 2009, 08:38 AM
cisco88's Avatar
Ignition coil ?
Is it normal for the ignition coil to get hot. This is on a 394 out of a 61 olds.
cisco88 is offline
Old January 27th, 2009, 08:49 AM
Past Administrator
Oldsguy's Avatar
No, you may have some faulty wiring or a bad ignition switch/solenoid. It may be that you have voltage constantly on that coil even when you turn off the ignition. If you have a way to check it do so, If not dis-connect the battery now until you get someone that can help you. That coil could get so hot the oil inside will leak out or even explode. I saw it happen once.
Oldsguy is offline
Old January 27th, 2009, 09:09 AM
cisco88's Avatar
Well it only gets hot like that when it is running, while ignition off, coile is nice and cool.
cisco88 is offline
Old January 27th, 2009, 09:14 AM
dan2286's Avatar
It is possible to overwork a coil while it is running, but I forget what can cause it. I think it can be something to do with having bad plugs/wires and maybe the distributor also.
dan2286 is offline
Old January 27th, 2009, 09:28 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I think it should still be running a resistor that drops the voltage to the coil. I would check that. It makes sense that if it were by-passed with a full 12 volts going to the coil, that it would overheat. Just my guess.
redoldsman is online now
matt68
September 11th, 2009 05:19 PM
NikkiLee
March 22nd, 2009 04:27 PM
liquidpower
February 28th, 2009 04:52 AM
1FSTLS1
December 20th, 2008 05:45 AM
68conv455
February 20th, 2008 02:36 AM
Quick Reply: Ignition coil ?
