1979 hurst olds headlight knob removal part 11
Old July 8th, 2015, 05:25 PM
Gmcdually's Avatar
1979 hurst olds headlight **** removal part 11
i have spent several hours for the last few nights trying to remove my headlight ****., with no success . I have seen photo of south and know where button is , but the switch itself is housed inside a plastic cover molded to dash and I cannot get to it . I have removed steering column trim and can see switch and get to it ,just can not get around plastic cover. I believe I can remove the two screws for switch itself,with this done will switch come out far enough to expose button., knowing that when **** is removed I can replace dash pad in five minutes , it has been a challenge not to get out the saw . HELP
Gmcdually is offline
Old July 8th, 2015, 08:14 PM
cherokeepeople's Avatar
didn't those have a tang on the back of the **** to depress,rather then the button on top of the headlight switch??look at the back edge of the **** for a notch this is where the tang will be.
cherokeepeople is offline
Old July 9th, 2015, 05:21 PM
Gmcdually's Avatar
Yes , you are correct. I did see the notch in the **** itself before and thought this must have something to do with removal. I used a small screw driver with slight pressure down and the **** itself came off without the stem . After I removed the dash pad ,I could clearly see switch itself and button , but would be impossible to get to from back as it is inclosed in a plastic sleeve attached to dash itself . Finally success with no damage and lesson learned thanks to all
halfmoontrail
November 20th, 2015 08:11 AM
July 26th, 2015 03:02 PM
Gmcdually
July 3rd, 2015 10:30 AM
Benton Quest
January 3rd, 2013 09:30 AM
gglow
February 22nd, 2010 12:47 PM
Quick Reply: 1979 hurst olds headlight knob removal part 11
