Timing light question anyone know where to find parts?
Old March 23rd, 2024, 06:26 PM
Gone Johnson's Avatar
Kind of a question related to Oldsmobile, but not Oldsmobile.
I got this killer Sears Craftsman timing light, part # 161.2134 .....
but the bulb burned out. I can't find the replacement part anywhere. Does anyone know a link, or have one that I can buy? Don't want Chineseium.... but that seems to be what everybody is going these days. I can't even find China stuff.
Well, Thank you in advance!
Gone Johnson is offline
Old March 23rd, 2024, 06:53 PM
'70 4-Speed W Machine
tnswt's Avatar
Sorry, I don't know where new replacement bulbs can be purchased for obsolete timing lights. I suggest to keep an eye on eBay to see if one shows up at a reasonable price that you can purchase and use for parts.
I use vintage timing lights also, and one day the same thing will happen--it will cease to function, so I keep a couple of spare units around tor parts.
The nice looking lights sell for good money,on eBay, but the dirty, greasy, and well-used units oftentimes can be obtained at very reasonable prices.
Note as well, that the bulb is a long service item, and your problem very well could be trigger, or voltage issues. Too, some models are not made to be repaired.
tnswt is offline
Old March 23rd, 2024, 07:53 PM
Those timing lights are all over ebay for $20-30.
oldcutlass is offline
Old March 23rd, 2024, 07:59 PM
v8al's Avatar
Take it apart and see what bulb is in it. I had one of those lights one issue was the plug wouldn't stay seated in the base of the handle.
Dial back timing lights have so much more flexibility. Take this as an opportunity to pick up one of those.
v8al is offline
Old March 24th, 2024, 05:48 AM
I have the exact same Sears Model 161.213400 (282134). These timing lights were Sold by Sears but not manufactured by Sears. They were manufactured by Actron. Actron has been a subsidiary of Bosch Automotive Service Solutions since 2012. The Part Number of the flash tube (600-258) is obsolete. No aftermarket parts are available.
You're far better to purchase a replacement off eBay or elsewhere (which has already been suggested).
NOTE: Double check the magnet(s) located on the clamp of the inductive input cable. They can become dislodged. The magnets pull the signal from the plug wire which is then amplified (500VDC-850VDC). If the magnets are not aligned, dislodged, etc. you'll get no light. Obviously ensure the battery clamp wires have no breaks as well as the inductive clamp input cable. It's possible to test voltage at the flash tube (what houses the bulb) to see if it's getting voltage which requires disassembly.
Vintage Chief is offline
Old March 24th, 2024, 10:09 AM
Thank you for the comments everybody. I have looked at used ones online, and of course that's an easy way to go - to just buy a new one. In spirit of working on old cars and loving them for what they are, I just wanted to buy a bulb for my timing light. I have diagnosed the bulb as bad, doing a simple continuity check. But yeah, guess I'll get a new light.
Old March 24th, 2024, 10:12 AM
..... also, I decided I'm going to remove the burnt bulb, and solder in a spare dome light bulb I have. Betcha it works!
Old March 24th, 2024, 10:18 AM
Loaded68W34's Avatar
I used one like the one above for years. Recently, I switched to one like this. It reads dwell, RPM, timing, voltage, and has dial back timing adjustment. Very happy I finally made the change.
Amazon Amazon
Loaded68W34 is offline
Old March 24th, 2024, 10:19 AM
​​​​​​​I thought those used a Xenon discharge tube? But maybe not all do?
Fun71 is offline
Old March 24th, 2024, 10:51 AM
Old March 24th, 2024, 11:03 AM
If that’s a discharge tube, it will measure open resistance. I suggest doing as noted above and measure to see if there is voltage at the bulb terminals when it’s supposed to fire. Might require an oscilloscope to measure the voltage pulse. You might be able to use a regular bulb to see if it flashes, but I suspect you won’t get many flashes out of a regular bulb before the bulb fails.
Fun71 is offline
Old March 24th, 2024, 12:01 PM
Yes, I believe you will be right. Dang it all right I'm going to give up. Or wait till I have a 12 pack one of the other. But yes I did consider measuring the voltage but took the easy route and just did a continuity test
Old March 24th, 2024, 12:32 PM
Let us know if you get a new timing light.
Olds64 is offline
Old March 24th, 2024, 12:39 PM
Will do 🤙
Old March 24th, 2024, 12:44 PM
If you choose this option, please video it. I’d love to see what happens to the bulb.
Fun71 is offline
Old March 24th, 2024, 12:46 PM
^x2^ Please do...my entertainment factor needs a boost.
Old March 24th, 2024, 01:35 PM
Will do....
if it's going to go down, it can go down in flames🔥🔥🔥
Garage28
March 29th, 2020 12:36 PM
yellowone
October 4th, 2019 06:45 PM
scrappie
April 22nd, 2019 03:45 PM
BangScreech4-4-2
October 1st, 2016 04:21 PM
Rocketguy
June 15th, 2015 08:16 AM
Quick Reply: Timing light question anyone know where to find parts?
