What do these wires go to
Old November 7th, 2020, 04:01 PM
benbarberco's Avatar
benbarberco is offline
Old November 7th, 2020, 04:41 PM
TimMC's Avatar
Need more info on car to know for sure , but kind of look like aftermarket stereo wiring.
TimMC is offline
Old November 7th, 2020, 04:42 PM
You were provided with an image of the wiring diagram.
You’ll need to read, review and follow the wiring diagram. I have suggested to you previously to buy the CSM where you will have a paper copy of the color coded wiring diagram. I suggest you buy it.
https://classicoldsmobile.com/forums...6/#post1261841
Vintage Chief is online now
Old November 7th, 2020, 07:55 PM
it’s 72 cutlass
Old November 8th, 2020, 06:03 AM
The out of focus square connector with the white, orange, and grey wires is the feed for the console.
Yellow should be the power feed to the original radio. It should have +12V with the key in RUN or ACC.
Solid orange should be the power feed for the dome and courtesy light circuit. It should be +12v at all times.
The wire with the single clear connector is too out-of-focus to tell what color it is. Is it grey or tan or pink? Grey would be the feed for the illumination (instrument panel lights).
joe_padavano is online now
oldcutlass
June 5th, 2022 03:01 PM
j808702
October 31st, 2016 07:50 PM
WolfmanG
January 16th, 2012 03:26 PM
bonezarally
July 26th, 2011 04:45 AM
442much
August 9th, 2010 09:11 PM
Quick Reply: What do these wires go to
