What do these wires go to
You were provided with an image of the wiring diagram.
You’ll need to read, review and follow the wiring diagram. I have suggested to you previously to buy the CSM where you will have a paper copy of the color coded wiring diagram. I suggest you buy it.
https://classicoldsmobile.com/forums...6/#post1261841
The out of focus square connector with the white, orange, and grey wires is the feed for the console.
Yellow should be the power feed to the original radio. It should have +12V with the key in RUN or ACC.
Solid orange should be the power feed for the dome and courtesy light circuit. It should be +12v at all times.
The wire with the single clear connector is too out-of-focus to tell what color it is. Is it grey or tan or pink? Grey would be the feed for the illumination (instrument panel lights).
oldcutlass
June 5th, 2022 03:01 PM
