radiator replacement
Old December 7th, 2017, 04:07 PM
kplange's Avatar
I'm looking to replace the radiator in my '81 Olds 98 with a 307. Obviously not a high performance vehicle. I'm seeing prices online, all over the map from $77 to $400 for this car. I'm sure there's a point where you're spending money unnecessarily. Are the cheaper ones with the plastic tanks any good? Any advice would be appreciated.
kplange is offline
Old December 7th, 2017, 08:43 PM
Aluminum core / plastic end tanks are OEM on all newer vehicles (1990-ish up) and work very well. They have a limited lifetime due to the core to tank seals eventually leaking or the plastic end tanks cracking due to age and heat cycling. Several of my newer vehicles radiators lasted 10+ years before starting to leak slightly, but replacements were under $100. All cooled very well even in the Phoenix summer 110+ temperatures.
Fun71 is offline
SteveL442
August 19th, 2010 02:59 PM
poorboy_616
May 18th, 2010 08:45 PM
poorboy_616
May 17th, 2010 09:54 PM
super88
July 19th, 2008 01:46 PM
HAFROD
March 20th, 2008 04:45 PM
Quick Reply: radiator replacement
