Valve Stem Seals
Old July 21st, 2012, 11:32 AM
aristellier's Avatar
Valve Stem Seals
I was getting a puff of smoke when pulling away after idling for awhile. Probably the valve stem seals, so I thought I would change them. This is what I found,
Think they needed doing!!
aristellier is offline
Old July 21st, 2012, 11:51 AM
Rickman48's Avatar
Those are better than most!
I did a '65 442 last year, mostly because the left side was smoking all the time - bad!
Small pieces of seal clogged the drain holes, and filled the valve cover with oil - straight down the guides.
Fun to clean-out!
Replaced with the hard plastic ones.
Shimmed the 46 yr. old springs, too.
Rickman48 is offline
Old July 21st, 2012, 12:06 PM
Eh, you still could a got maybe another 100 miles or so out of em. Yes, they are entertaining to change! The engine looks to be clean of sludge, thats a perk!
oldcutlass is online now
Old July 21st, 2012, 12:35 PM
Lady72nRob71's Avatar
Wow - I am surprised that you just a few puffs! Those things are GONE! At least the heads are nice and clean.
I changed mine last year and not one was broke. Makes me wonder if they were changed long ago.
But my heads were NASTY. I could not even find oil return holes...
Here is my fun:
https://classicoldsmobile.com/forums...tml#post294407
And the seal replacement...
https://classicoldsmobile.com/forums...tml#post317189
Lady72nRob71 is offline
esisson
June 7th, 2023 07:44 AM
rockettruck
November 5th, 2012 07:28 PM
Redog
July 4th, 2011 06:11 AM
defiant1
January 27th, 2011 06:47 AM
Half Baked
January 10th, 2008 08:43 PM
Quick Reply: Valve Stem Seals
