No more points!
Old March 25th, 2017, 08:59 PM
Bryan Burch's Avatar
Smile No more points!
Dropped the points for a Mallory E-spark. Fired first crank, running stable.
Bryan Burch is offline
Old March 27th, 2017, 08:53 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Make sure all...ALL grounds under the hood are present clean and tight for years of trouble free operation. This includes the braided straps from the head to the firewall. Get an assembly manual for specifics. If not the module in the new dist will be short lived. Ask how I know...
droldsmorland is offline
Old March 27th, 2017, 05:43 PM
Alright, you got the fear of fail in me. I'm checking everything. Thanks for the tip!
Old March 27th, 2017, 06:19 PM
... And carry the old points and condenser (or the old distributor, if you replaced the whole thing) in the trunk, just in case.
When points go, you can usually futz around a bit and get home.
When electronic ignition goes, you're usually parked until you get help.
MDchanic is offline
Old May 27th, 2019, 01:22 PM
stix's Avatar
Hows the mallory module holding up after 2 years??
stix is offline
Old May 28th, 2019, 05:38 AM
Flawless! However, my near term plan is to ditch the stock vacuum advance distributor and replace it with a locked out msd pro billet and let my EFI control the timing. I already have everything I need, just need to dive in.
dynamic88builder
December 30th, 2019 07:24 PM
Oldssupreme
November 19th, 2018 04:48 AM
redoldsman
September 5th, 2017 08:54 AM
brown7373
October 11th, 2014 10:51 AM
Frankenpez
February 8th, 2009 07:38 PM
Quick Reply: No more points!
