Name that tool
Old May 21st, 2019, 08:24 PM
Mr Shifty Sidney's Avatar
Name that tool
I'm a sucker for odd tools in the dollar bins at swap meets. I picked this up recently. Google has not been helpful. K-D 2022 is stamped on the handle. What is is for?
Don W
Mr Shifty Sidney is offline
Old May 21st, 2019, 09:43 PM
ELY442's Avatar
Its for removing and installing a muffler bearing
ELY442 is offline
Old May 22nd, 2019, 04:12 AM
68442's Avatar
Left Or Right
68442 is offline
Old May 22nd, 2019, 04:38 AM
JohnnyBs68S's Avatar
Its clearly an expander.
What it expands, is another question. Something with a square-ish cross-section, I'd guess.
JohnnyBs68S is offline
Old May 22nd, 2019, 04:54 AM
rob1960's Avatar
Looks like something to do with adjusting/holding brake shoes, maybe the old non self-adjusting type???? I have a bunch of old K-D drum brake tools but that's not one of them. I had no luck searching it either.
rob1960 is offline
Old May 22nd, 2019, 04:56 AM
Kensey's Avatar
Looks like it would be for expanding, or holding in place, drum brake pads.
Kensey is offline
Old May 22nd, 2019, 06:21 AM
442Harv's Avatar
How long is it? Could it be used to put on and take off hood springs?
442Harv is offline
Old May 22nd, 2019, 06:46 AM
boese1978's Avatar
Spring spreader? I for one would not use that wimpy rusty thing on a hood hinge!
boese1978 is offline
Old May 22nd, 2019, 08:36 AM
Ancient Iron's Avatar
K-D 2022 Brake Star-Nut Adjuster
It's for spreading brake shoes to remove/ install the star adjuster on drum brakes.
From my 1973 K-D tool catalog
Ancient Iron is offline
Old May 22nd, 2019, 09:31 AM
Thanks Ancient Iron. I thought it might be brake related. I bought a Blue Point drum measuring tool also in the lot of tools.
Don W
Old May 22nd, 2019, 09:56 AM
Your welcome
Neat tool and for a real cool price .... Now I want one LOL.
Old May 22nd, 2019, 10:04 AM
Very cool.
I thought you were supposed to get a t-shirt or hat from the tool truck guy if you needed a tool that he wasn't familiar with. I was wrong though. I ordered this from a SnapOn guy recently:
It's a piezoelectric pulse adapter to set the injection pump timing on a mechanically injected diesel. I got it for my 86 Ford f250. I guess I need to track down an Olds diesel now since I have a tool I could use with it!
Olds64 is online now
Old May 22nd, 2019, 11:19 AM
same but different
don71's Avatar
I spent some time last night looking (googling) and not one picture or even a clue to its identity was found. I tried my darnest
I think you stumped the google. I'm glad we have the community here, for just this thing.
don71 is online now
Old May 22nd, 2019, 06:28 PM
cherokeepeople's Avatar
Originally Posted by Olds64
Very cool.
i used to have one of those and used it on the 5.7 diesels.
cherokeepeople is offline
Old May 24th, 2019, 08:59 PM
Schurkey's Avatar
The Olds 5.7 sold a lot of Snap-On MT1480 Lumy-Mags. You'd set the timing by comparing the instant that the burn started in the chamber (based on the chamber lighting up as seen through a luminosity probe screwed into the glow-plug hole) compared to the magnetic crank sensor reading the 'slot" in the torsional damper. The timing cover has a holder for the magnetic probe, but GM didn't install a dedicated crank sensor.
Of course, you could set timing on a spark-ignited engine too--comparing the spark impulse in the plug wire to the crank sensor at the damper. Again, GM installed a holder for the probe, but no sensor.
The tool has a readout for degrees of advance, and RPM.
Photo of my second MT1480, set-up for spark ignition timing.
Schurkey is offline
December 25th, 2018 01:22 PM
mother$hip89
September 28th, 2018 01:22 PM
Troys Toy 70
May 1st, 2018 09:14 PM
jaunty75
March 4th, 2016 02:21 PM
HeyitsAaron
June 9th, 2010 07:57 PM
Quick Reply: Name that tool
