Bell Housing ID
Old October 15th, 2009, 04:02 PM
mono-plane's Avatar
Bell Housing ID
I have started sorting thru my parts for my F85 W31 ex-race car, in order to see what I have that might be original to the car. My bell housing is an aluminum BOP style with an irregular shaped hole (sort of looks like a profile of a house with a peaked roof) at the bottom of it, like an inspection hole? The number on the housing is 9785581.
Can anyone identify this piece for me?
As well the trans that I have is a Borg Warner (not the original M21 as per my documentation) 4 speed. I have identified it as a May 9th 1975 Pontiac piece. Is there a real good website to identify exactly what this came out of? It was behind a 400 or 455 likely? I have got all of the numbers/letters off of it and decoded some of this info, but many of the numbers I have no reference for.
Last edited by mono-plane; October 15th, 2009 at 04:09 PM. Reason: Added more text
mono-plane is offline
Old October 15th, 2009, 04:40 PM
Registered
Bluevista's Avatar
I figured it may be Poncho with that tranny so I looked in the GTO resto guide.
It shows that part number 9785581 is a 1965-70 GTO aluminum bellhousing, I don't know if it may be used in other cars too but it does show it for the goats.
I would try the PY forum if you want to ask about any Poncho stuff, good site.
http://forums.performanceyears.com/forums/
edit: I should of looked in the Oldsmobile parts book too.
Shows the bellhousing is for a 1964 F85 V8, 1965-75 V8 and a couple of others.
Bluevista is offline
jensenracing77
December 20th, 2022 12:37 PM
brandon reynolds
March 16th, 2010 07:02 PM
silverriff
November 17th, 2008 06:29 PM
dan2286
July 26th, 2008 05:00 PM
ozoneblue
August 21st, 2007 05:59 PM
Quick Reply: Bell Housing ID
