Battery Cables- factory correct 1970
Old July 10th, 2012, 01:03 PM
Del70's Avatar
Thinking about ordering battery cables for my 70 from fusick. They don’t offer a good picture of the product. For those who have bought them, how is the quality, correctness?. Any pictures?. Any other supplier suggestion based on fist hand ownership.. Thanks
Del70 is offline
Old July 10th, 2012, 05:23 PM
442Harv's Avatar
Fusick will sell you a good quality cable.
442Harv is offline
Old July 10th, 2012, 05:52 PM
joesw31's Avatar
I have purchased there battery cables from Fusick and the quality is equal to the original and look identical.
joesw31 is offline
Old July 10th, 2012, 06:39 PM
I have no doubt that Fusick sells a good cable. Only thing is you have to read carefully. For 1970 no problem getting the right one. My car is 72 and the Fusick catalogue lists them as side post. Mine is a top post. So I would have to order 71 cables. I know that 72 Cutlass models came with side and top post cables.
Allan R is offline
Old July 10th, 2012, 07:34 PM
w31man's Avatar
Battery cables
I bought mine from inline tube and they fit and look fantastic!
Just my 2 cents
Greg
w31man is offline
Old July 10th, 2012, 10:22 PM
stevengerard's Avatar
They all seem to be made by the same two wire companies. Just make sure you get the correct one for your application, they look correct and work fine - no worse no better than an original
stevengerard is offline
Old July 11th, 2012, 03:52 AM
Del70's Avatar
thanks
Del70 is offline
Old July 11th, 2012, 06:38 AM
Lady72nRob71's Avatar
I bought mine (for a 72) from Fusick and they looked and fit great. They were made by American Autowire. I found I could have saved 20 bucks by ordering through Rockauto, as they sell AAW also.
Lady72nRob71 is offline
Old October 10th, 2012, 03:56 AM
Del70's Avatar
Picked up a positive and negative cable from americanautowire. I am very impressed, they look very well made (time will tell). The part numbers are stamped into the cable as they should be with a light amount of white paint to highlight the numbers as they should have - just like my original factory negative battery cable has. I tossed out my factory positive cable many years ago (why I don’t know) so I can’t compare the red color to the factory red cable, but from the pictures I have it appears to be correct.
Del70 is offline
Old October 10th, 2012, 04:19 AM
My442's Avatar
I had my cables made by M&H in a heavier gauge wire than stock.
Look stock, but perform better.
My442 is offline
Old March 15th, 2013, 07:19 PM
442dale's Avatar
1970 442 Pace Car Battery Cables
I would like to replace my cables but I'm not sure if one of the previous owners beat me to it with incorrect ones.
I have a 1970 442 Pace Car and my question is did my car originally come with top post spring type connectors?
The current cables have a nut to tighten to the post. I think that is more commonly found at the parts store but I thought I would ask first before purchasing.
Also, anybody know what brand Parts Place carries?
Thanks.
442dale is offline
Old March 15th, 2013, 08:09 PM
charlierogers's Avatar
Thanks.
your pace car originally had top post neg cable with bolt to tighten and the positive had spring type clamp. i used the ones from inline tube and the fit and finish are correct.
charlierogers is offline
Old March 15th, 2013, 08:21 PM
Charlie is right on with his answer, I believe parts place has the correct ones, that is where I got mine
by the way you should make sure you have the battery tube that mounts to the frame near the firewall that protects the battery. Most likley you have one but now would be the time to check. I think I have a few of those sitting around and they make repos at least for the automatics.
Old March 15th, 2013, 08:23 PM
442dale's Avatar
Thanks guys, I will have more questions as I get going on this car.
442dale is offline
Old March 16th, 2013, 07:21 PM
Formerly "Shimmer"
Al Graaf's Avatar
Just my 2 cents
Greg
InLine or M&H diffenately.Just a Kentucky opinion of course. I do like InLine.Bought thousands from them. AND no green stamps!
Al Graaf is offline
gardizzle86
August 22nd, 2011 08:57 PM
cornwallis
October 12th, 2010 05:42 PM
Del70
September 28th, 2010 04:21 AM
georgiaboy697
July 8th, 2010 04:59 AM
silverriff
March 12th, 2010 04:22 PM
Quick Reply: Battery Cables- factory correct 1970
