Another tool that works
One of the problems I've always had when plumbing brakes is deburring the cut brake line before flaring. I usually ended up using a file for the outside and a knife for the inside, which never really left a very nice finish. I recently picked up the Eastwood tube deburring tool during one of their recent discount sales, as I needed an extra item to get over their free shipping threshold. I finally got the chance to try it this morning, as one of the lines on my wife's 1985 D88 finally rusted out. I have to say, this tool makes it very quick and easy to dress the end of the tube for flaring. A lot of what Eastwood sells is gimmicky and somewhat overpriced, but this tool works as advertised.
I have had one these for 28 years. I worked for a machine shop for 1.5 years. $11.95 today probably back then was $5
http://www.pts-tools.com/Product_Ima...m/F/FN50-B.png
Pat
Pat
Pat
Pat
That Eastwood tool is good, but If you don't have one a small Diameter drill bit on a low driver speed in a cordless drill would work ok for the ID of the brake line.
I agree the deburring tool that Pat posted would be for larger Diameter holes and insert pockets in a machine shop. However Shaviv does sell a countersink type deburring tool as well, similar to the Eastwood tool .
Eric
Eric
Actually, you said this:
I assumed anyone interested would just go to the Eastwood site for info. I DID say it was for brake lines, however. That means either 3/16" or 1/4" tubing.
Another thing, you did not give details on pricing and tolerances for working with it!
[QUOTE=joe_padavano;985090]Actually, you said this:
Pat, stated he worked in a machine shop for a year and a half using deburring instruments. I would think he meant the Shaviv deburring instrument lineup. Since they have all types of deburring instruments from small ID/OD holes to larger.
That's what I gather from his post.
Either way , the Eastwood Tool you posted looks like it would be a great buy for brake lines. Two in one tool ID and OD.
Thanks for posting.
Eric
Thanks for posting.
Eric
McMaster has a nice one I use all the time.
https://www.mcmaster.com/#chamfering...sinks/=1619c5r
That's cool that it is a good tool and not just Chinesium junk. I'm actually surprised that Eastwood would carry a tool like that. I thought Eastwood specialized in auto body tools and products. That tool is something I would expect to find at Summit or Jegs before Eastwood.
Cool tool.
Eastwood sells all kinds of stuff, not just body stuff. I was checking out a 4-bank battery tender they were offering before I bought it for half the price (same unit) on Amazon.
Rigid makes a reamer that should work for 1/4 up to 2" for copper and steel. It's used by a lot of tradesman for that purpose. I use it on copper , but have never used it on brake lines. It does the inner and outer dimensions of tubing .
Thanks for the heads up Joe! and thanks Eastwood. Swagelok has a tool(s) for this too, but they are much larger. This one is specifically geared towards us car people. Looks like its nice and compact as well. I like it and the price is right.
there is also a lapping tool for after the flare is made, a little pricey, but may ensure a leak proof seal. if the price ever comes down I might consider it.
http://koultools.com/product/flare-lapping-tool/
bcracing
Care and Appearance
October 13th, 2009 05:05 PM
