65 442 brake light problems
brake light issues
There is no four ways and all the lights seem to work normal.I ordered a manual that should help.I never have known how they isolate the turns from the brakes without having feed back. Thanks for the reply.I will keep you posted Jim
Signal light switch in thc column, then.
There's always a chance you can clean it up and get it working, but the complete assembly may be a bit hard to find new.
NAPA does have a "repair kit," though, consisting of a single part, which may be what you need.
I agree. The switch isolates the brake from the turn. With brake pressed volts go through the turn switch. When switch is centered, both brake lights are lit. When switch is on right turn, brake volts go to left light and vice/versa.
yeahbuddy
Brakes/Hydraulic Systems
January 15th, 2014 02:10 PM
Del70
August 2nd, 2011 04:40 PM
