1964 442 original water pump material
Old May 24th, 2019, 04:08 AM
dmw
dmw's Avatar
I have a 1964 442. The water pump on the car is starting to leak. The housing for this pump is aluminum. I have an old water pump core for a 1964 442 that is cast Iron. Was the original water pump housing cast Iron or aluminum for the 1964 442's?
dmw is offline
Old May 24th, 2019, 06:43 AM
2blu442's Avatar
I've seen several aluminum ones but only one cast iron and I'm not sure if that's OEM or aftermarket. So I believe they made both, but clearly the aluminum was the most common.
2blu442 is online now
Old May 24th, 2019, 09:46 AM
The Rocket Astronomer
lunaboy's Avatar
i may have a rebuilt cast iron one if your interested
lunaboy is offline
Old May 24th, 2019, 11:14 AM
dmw
dmw's Avatar
Yes I am interested in buying a rebuilt pump. I do not know if the original pumps were cast Iron or aluminum. I have both that are good only for cores Does your Cast iron pump have a casting number? If so what is it? I've read that the casting number should be 382188. My old cast iron pump for a 1964 330 has the casting number: "30597". My aluminum pump has no casting number.
dmw is offline
Old May 25th, 2019, 03:05 PM
Cruiser Bob's Avatar
I had a new 64 442 and I know for sure it had a cast iron water pump, it was mid model year production
Cruiser Bob is offline
Old May 25th, 2019, 03:35 PM
therobski's Avatar
There are places to have yours rebuilt, if you want to stay original...it is an option. If you go with another one make sure the shaft lengths are the same..Don't know if that makes a difference on a 64 330, but later year A-Body cars with options it certainly did.
therobski is offline
Old May 25th, 2019, 04:25 PM
lunaboy's Avatar
i think the casting should be 381288 but not sure. i have an aluminum rebuilt
one with this casting
lunaboy is offline
Old May 25th, 2019, 07:36 PM
dmw
dmw's Avatar
I have a cast iron water pump for a 1964 330. It is unique because it fit only the 1964 year. The only thing that concerns me is the casting number. It has a funny casting number of 30597. Does anyone know if this is or may be the original casting. It has minimal pitting and would be easy to rebuild.
dmw is offline
Old May 25th, 2019, 07:45 PM
Phantom Phixer
Charlie Jones's Avatar
With a 5 digit number that pump is probably an old aftermarket pump .
Aftermarket manufacturers often supplied cast iron pumps to replace the sometimes troublesome aluminum pumps of the time .
If you can get it re-built that would be a good pump to use .
Charlie Jones is offline
Old May 25th, 2019, 08:55 PM
dmw
dmw's Avatar
Charlie, thanks, your right it does makes since that with a 5 digit number the pump is probably an old aftermarket pump . The pump also has a symbol cast into it. This may be the pump manufacture's symbol. I will try to get a photo of the symbol tomorrow and post it. Maybe someone will recognize it. Thanks
dmw is offline
dmw
October 9th, 2019 07:07 PM
junior supercar
January 31st, 2015 07:39 PM
ferndaleflyer
May 27th, 2014 02:53 PM
wizard
Tech Editor's Desk
June 28th, 2013 05:25 AM
wizard
June 27th, 2013 07:50 AM
Quick Reply: 1964 442 original water pump material
