Ignition Switch
Old April 26th, 2015, 04:24 PM
Ramirez007's Avatar
Ignition Switch
Need help on replacing an ignition switch for a 74 Olds Delta 88 ?
Ramirez007 is offline
Old April 26th, 2015, 05:30 PM
If you are talking about the electric ignition switch and not the lock cylinder, just drop the column. You'll see the switch on the top side of the column, near the firewall.
joe_padavano is offline
Old April 26th, 2015, 07:24 PM
+1. You can't miss it. Two screws.
Why do you need to replace it?
MDchanic is offline
Old April 27th, 2015, 05:49 AM
oldspackrat's Avatar
Maybe he means the key & tumbler? If so, also easy enough if you have the right tools to pull the steering wheel & lock ring.
oldspackrat is offline
Old April 27th, 2015, 06:09 AM
As well he may. Of course, we'll never know if he doesn't say that.
And, though it is annoying and painful, I have never had a problem getting the lock ring off without the special tool (I'm a glutton for punishment ).
MDchanic is offline
Old April 27th, 2015, 07:45 AM
Which is why I noted that in my first post. The mind reading thing still isn't working.
Wasted
October 26th, 2018 02:57 PM
Benny Blanco
May 25th, 2008 04:17 PM
47 Coupe
May 9th, 2008 08:38 AM
mm89olds
April 6th, 2006 11:03 AM
oldbutgood
November 12th, 2002 10:00 PM
Quick Reply: Ignition Switch
