"Corrected" HEI cap
"Corrected" HEI cap
Has any one ever used one of these?
ACCEL makes a corrected HEI GM cap and rotor kit that is supposed to put all the EVEN wires on one side and then all the ODD wires on the other to prevent the "tangled up" look.
http://www.raceindustry.com/part-sho...i-cap-kit.html
Believe it or not, the plug wires are routed in a certain way to reduce crossfiring and inductive electrical interference. I've seen it addressed in some early 60s Service Guilds and Tech Bulletins.
Yes, you don't want the wires for successive cylinders in the firing order to run parallel to each other. 5 and 7 is the pair you need to look out for on an Olds. 8 and 4 to a lesser extent.
joepenoso
June 4th, 2014 01:56 PM
81 regency
April 21st, 2011 06:18 PM
