65 Starfire fuel tank sending unit
Old November 9th, 2012, 12:08 PM
You Skin that Smokewagon
JOE CAPP's Avatar
Hello all, I would like to know if there are any a or b body fuel tank sending units that would work in a 65 Starfire fuel tank, it is mounted in the front on the side not the top of the tank and also it is 90ohm full. This one is the 2 line with ac, Any help would be appreciated.
JOE CAPP is offline
Old November 9th, 2012, 02:37 PM
radioburningchrome's Avatar
Your best bet would be to take the unit off the tank and try to match one up in an auto parts store.
Option 2 is to find one on ebay.
Good luck
radioburningchrome is offline
Old November 9th, 2012, 03:28 PM
REDJET's Avatar
Hi Joe Im Vernell I bought 2 of them from Autopartswarehouse 1 for my 65 jetstar1 and 1 for my 65 Starfire I cant find my reciet now but I looked @ 65OLds @ 65 CHEV found pictures of the ones I needed . They matched up and work great. Good luck from REDJET.
REDJET is offline
Old November 9th, 2012, 03:43 PM
JOE CAPP's Avatar
Hey Vernell ,I tried Autopartswarehouse and no luck, do you have a model number ? Thanks, Joe
JOE CAPP is offline
Old November 12th, 2012, 03:23 PM
http://www.summitracing.com/parts/amd-881-3464-5
Does that look close?
Old November 12th, 2012, 03:36 PM
JOE CAPP's Avatar
thanks for the effort but the Starfire has a 2 line, 1 feed 3/8" and 1 return line$(KGrHqYOKigE0nlO3f8hBNce990TP!~~_1.JPG.jpeg
JOE CAPP is offline
Old January 5th, 2014, 02:57 PM
65Delta88J-Scril's Avatar
Did you ever find one and if so WHERE?????
65Delta88J-Scril is offline
Old January 5th, 2014, 06:29 PM
JOE CAPP's Avatar
I found the sending unit on EBAY used but I'm pretty sure that a Spectra FG88E sending unit will work they are $35 on ebay they are 90 ohm and have the 3/8" inlet and 1/4" return. may be worth a shot.
JOE CAPP is offline
Old February 19th, 2017, 06:04 PM
65Fire's Avatar
I don't see ANYTHING out there. None of the leads I've seen have come up with one. O'Riely and The Zone didn't have it in their catalog. Nothing at Dorman. It doesn't look anything like what I've been able to find pictures of.
I took the rheostat apart on mine, thinking there might be something simple. A bunch of rust and garbage fell out. the coil is still in good shape with the right resistance, but the contact was trashed beyond repair.
SOMEONE must have one of these things. Even a used on that works.
Does anyone repair them or have just the float/rheostat assembly I can attach to my pickup tube?
Any other ideas?
This is it:
65Fire is offline
Old March 12th, 2017, 07:24 PM
65Fire's Avatar
Made one
Any other ideas?
This is it:
i made one!
Attached el cheapo float and rheostat to original pickup tube
Old one and new one
65Fire is offline
Old March 13th, 2017, 09:01 AM
Very nice. Want to tell us where you got the rheostat?
joe_padavano is offline
Old March 13th, 2017, 11:44 AM
65Fire's Avatar
ebay
I got it on Ebay for $18. There are others that look usable. search Ebay for this:
"Fuel level sender sending unit, GM type, 0-90 ohms, 6”- 24” adjustable"
The sensor comes right off with 2 screws. I made a bracket from a flat piece of aluminum from Lowes. Drill a couple holes it in it lined up with the sensor holes. Put the aluminum on one side and the sensor on the other. hold them together with 2 screws. it is tricky to get the float lined up right. in this case, it needs to be close to the bend so it fits into the hole in the tank. the orientation could definitely be better than I managed. don't cut the rod until you have it right where you want it with full sweep going from the bottom of the tank to the top - ~8" in this case. solder the wire to the inside of the flange where the original was connected. zero ohms empty. 95 ohms full.
65Fire is offline
dallasite21
October 1st, 2021 05:21 PM
68RocketAction
December 18th, 2014 11:19 AM
pfergy600
October 4th, 2014 05:29 PM
1carsick
October 17th, 2012 09:10 AM
wikkonado
June 19th, 2010 07:28 PM
Quick Reply: 65 Starfire fuel tank sending unit
