High beam indicator
Old July 30th, 2011, 06:17 AM
msco123's Avatar
High beam indicator
My high beam indicator does not work. I have pulled the gauge and checked the bulb and it is good when I hook it a direct power source. I does appear the some bulbs are dimmer or not working on one side of the gauge. But all bulbs check out when directly powered. Any suggestions?
msco123 is offline
Old July 30th, 2011, 06:32 AM
CQR
CQR's Avatar
May need a little more information. Year, Model, etc. Usually dim bulbs are a bad ground issue.
CQR is offline
Old July 30th, 2011, 06:52 AM
Lady72nRob71's Avatar
Clean contacts of bulb sockets, circuit board pads, and cluster connectors.
Lady72nRob71 is offline
Old July 30th, 2011, 07:00 AM
The indicator lamp is powered from a wire that comes directly off the dimmer switch. If the high beams come on, there is power at the output of the switch. Start there. Disconnect the wires from the dimmer switch and apply +12v to the high beam wire. If the indicator lamp still doesn't come on, trace the circuit. Check this wire for continuity where it plugs into the instrument panel connector. If bad, fix the break. If good, check the connections on the indicator lamp socket. Be sure the ground side is making contact also.
joe_padavano is offline
Old July 30th, 2011, 07:08 AM
msco123's Avatar
Appreciate the help, guys. Car is a 73 cutlass supreme.
msco123 is offline
Old December 3rd, 2011, 10:45 AM
Cruizin
RenderPit's Avatar
Good info, thanks
RenderPit is offline
Trentg89
February 14th, 2015 07:16 PM
RenderPit
Ninety-Eight
21
June 8th, 2013 04:52 PM
woody30
Tech Editor's Desk
September 15th, 2012 08:45 AM
kandelino
November 5th, 2010 06:45 AM
BaileyJD1
May 1st, 2008 11:45 AM
Quick Reply: High beam indicator
